Solar cooling with 2 clay pots ! Very cheap genius idea !
Started by hartiberlin, April 29, 2008, 07:25:50 AM
hansvonlieven
G'day Dave,
The answer is yes, Stirling motors have been built that use evaporative cooling to increase output. The so called dipping bird or its more modern version the Minto wheel also rely on evaporative cooling for their effect.
Hans von Lieven
ResinRat2
Hi Hans,
I think I remember you saying something about submarines that used stirling engines. What was the substance that it used to store the heat? Something about a tank filled with this component that held heat for the engine. I'm thinking of filling the center pot with whatever that was, that way it would be easier to hold the temperature difference.
Thanks
ResinRat2
Aha!!  Found it:
aluminium oxide pellets
Thanks Hans!!
hansvonlieven
G'day Dave,
From memory the medium to store heat were aluminium oxide pellets.
Hans
hansvonlieven
