Dbowling
I can see the four I posted, but it won't let me post the rest. I keep getting the "failed security check" and I know that these scans have no security issues because I scanned them myself.
Please post it in a smaller resolution.
For these note pages the resolution
of 1024x768 would be enough.
Just use the free Irfanview.com
program to scale them down and use 80 % JPEG
quality and then the files will only be around 100 to 300 Kbytes,
so the server will accept them much better...
Regards, Stefan.
Dbowling
IThanks Stefan, I did as you suggested. Hopefully that will make a big difference.
Dbowling
And the last page. I hope this is of use to folks.
I will be spending a lot of time trying to repeat this experiment. The key is, when you make all your connections, and the motor starts up immediately, you don't have a battery in the third position that is going to make this thing work like I had it working. So the first step would be to keep trying "bad" batteries in the third position until you get the setup where the motor does NOT come on immediately, but takes several minutes and then it suddenly starts. But PLEASE remember this. I think that perhaps the constant charging and draining of my battery in the third position eventually did something to rejuvenate that battery, and once that happened, it no longer worked. Or at least that MAY have been the reason it no longer worked.
Regardless, I have not given up on this idea. If you had seen what my boys and I saw, you would never give up either!!!
SkyWatcher123
Hi david, thanks for sharing your information.
It almost sounds like beardens degenerate semiconductor effect, where your batteries 1 and 2 are making a voltage connection with battery 3, yet not allowing current to flow back to them and destroy the dipole.
Instead, they were maintaining or charging due to that effect, like a true one way diode, yet something of a different nature electrically, was feeding back to batteries 1 and 2.
Maybe a radiant type of energy.
One might assume then, that some kind of crystal battery may achieve the same effect, if placed in battery 3 position.
I'm sure some black project already figured this out and built a transistor of some type, that does this very thing you observed, using just one battery, load and degenerate crystalline transistor or diode.
peace love light
