How to make bedini motor overunity ???
Started by capacitor70, May 03, 2008, 12:09:12 PM
Ren
Why would a larger device produce overunity, where a smaller device would not?
[/quote]
Because it will produce more mechanical power.
shruggedatlas
Quote from: Ren on May 03, 2008, 06:33:33 PM
But wouldn't it also require more energy to run?  For example, in a car, technology being equal, a larger engine produces more power but also consumes more fuel.
Ren
 :D Yes thats true. But you have to understand that when it is done correctly more on the front end means more on the back end. So you will need a larger batteries etc but the effect is still the same. Perhaps you are forgetting that there is a battery charging on the back end, whereas a conventional engine whether electric or ICE doesnt have a form of recovery for the energy spent to achieve rotational torque
capacitor70
I tried bifilar wound coil it doesent make any differance. Putting diode in pulse pick up coil to dischrge the
back emf it increases efficieny by 5%. Mechanical output, RPM I am getting with bifilar coile is much high nearly 8000 to 10000 RPM @ 300mAmps 12V.
I have not tried to take output from this mechanical power, it may take me near unity.
Another machine today I build with relay it gives me 8 to 13Amps output @ 12V and input is 0.02Amps @ 12V. This is meter fault, meter does not responce properlay for high voltage spikes
Machine design
1. Relay NC connection is giving supply to relay. When Relay becomes on as soon as it disconnects its own
supply so it becomes off and agin the cycle is repetated this way it starts oscillation.
2. Simillar to bedini design connect battery with diode to take back emf to charge it.
3. Tried with replacing meters, Both meter shows same result some times DMM hangs. I dont have Analog Ammeter.
Feynman
Can you post the schematic you are using?
