I'm not one to get prematurely excited...but can someone explain this
Started by Cap-Z-ro, May 08, 2008, 06:34:41 PM
FatBird
@ IronHead
I have read numerous admonitions that Cold Electricity current, aka Aether current, cannot be measured in a conventional manner with an Ammeter or MilliAmmeter.  I think the best we can do is monitor the battery voltages to see what is going on.
What is your opinion?
IronHead
Yes that is correct . Scalar potential as such will shoot right through the meter backward. Again the word "backward" is used loosely here as direction is also very hard to explain such as the word spin when talking about such energies.We jump far outside of the flat space laws of thermodynamics here.
The meters of today will not measure such an energy type unless it is greatly slowed to the speed of light and captured in a magnetic field , which is achievable but rare. You see a glimpse of this  in Tesla, Beardon,  Badini, Mullar and others works.
Lets keep it simple for now.
MeggerMan
Quote from: FatBird on May 11, 2008, 05:44:32 PM
@ IronHead
Yes, I was going to say cold electricty too.
There is no current flowing that I can measure +/- 10uA
I will give is a day or so and see what happens.
What I did notice is that when I connected the meter the voltage was climbing at a random rate and seem to be climbing faster because I was standing over it.
Also when the battery gets to about 8.4V I can then test the capacity using a Peak Prodigy Pro battery analyser and then repeat the experiment so I will be able to measure the gain in power.
Mine is the original version of this one:
http://www.ripmax.com/item.asp?itemid=O-IP2801
Voltage is now 4.230V and that's a climb of 0.546V in 1 hour so by the morning it should be up to about 8.5V, but I think it will slow down as time goes on.
So far so good.
Rob
resonanceman
Quote from: IronHead on May 11, 2008, 05:51:52 PM
The meters of today will not measure such an energy type unless it is greatly slowed to the speed of light and captured in a magnetic field , which is achievable but rare. You see a glimpse of this  in Beardon, Badini, Mullar and others works.
Ironhead
For now I am going to assume that I am right about  the  induuctors   picking  up  RF of some kind .......and  between the  coils and the caps  a  vibration is formed
That vibration  would cause a vibration in the aether  .......and that would cause a flow of  aether energy .
How  would  we  best use or convert  this  energy ?
I was  wondering   if   it could be  this  aether flow that was charging  the batterys .......but it would almost have to be an AC flow to get through the caps
I would think that an AC flow would tend to discharge more than it would charge  because of the  already  present  voltage  difference
gary
IronHead
I do not think any of us know yet if the batteries are charging with a usable current.
If this is a Ghost Charge then we have no usable energy here.
Edited
If this is "aether energy" causing the Ghost Charge then it is back to the system most of you all have been striving to create , The Aether Converter. A system that captures the current from such an energy . Normally slowing the wave in a very long wire ( at least 1000 feet) with an applied strong magnetic field. Or in a  spark gap.
