Microwave Oven Hydrogen Production
Started by sparks, May 12, 2008, 05:10:11 PM
sparks
    I was studying MRI machines and how they work.  I was wondering  if a strong diamagnetic field was used to alter the magnetic resonance of say a saltwater solution and then smack it with microwaves what would happen.  I wonder if this could cause disassoctian of the water molecule and produce hydrogen gas.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Haliburton
i brought up this question in this forum long ago.  nobody cared  :(
comp-tech
Hi Sparks,
I watched this guy's experiment with grapes to create a plasma in the microwave.
http://www.youtube.com/watch?v=vCNNqgKqnaQ
So, I tried it myself. It works, but it seems to work only with that particular shape of the object. If I did not cut the grape the same way it did not work. So, it looks like a "dipole shape" plays some kind of a role there. I was going to try it with the salt water too but I did not yet. It is certainly interesting and I believe that the disassociation of water takes place there.
Goat
@ Sparks
I was wondering one day a while back, if you had a Bingo fuel type setup in a microwave with the carbon rods acting as antenna's to make the reaction rather than using a welding machine.  The old microwaves didn't have a turntable in them and worked fine, albeit a little uneven heat, and there's also microwaves with a hole on top for a thermometer that could be used for the discharge tube (I think).
Anyway, just throwing the idea out there in case I get hit by the bus of life!  You're thread seemed like a good place to it :)
Regards,
Paul
sparks
   Thanks guys for the interest.   I saw a utube demonstration of rf catalyzing water disassociation.  Since then it has been removed from utube because of some bullshit about violation of terms.  Probably because the person who was reporting this phenomenon owns his own radio station.   Next thing this poor man will have happen to him is that the fcc will be up his butt trying to pull his license.   I suggest that it is too late.  Keep up the work guys.
   If you put a conductor in there the microwaves will produce voltage gain like you wouldn't believe.  I am sure all of us has seen the lightning bolts from inadvertently putting a metal in a microwave.  Overunity or just conversion of mass to energy?  You don't need to split the atom just expose the atom to a little rf and e=MC2 goes to work.
Think Legacy
Spread the Love
