Repelling "Fan" theory for a magnet motor
Started by Dact, May 15, 2008, 10:48:09 PM
Dact
Quote from: gyulasun on May 16, 2008, 07:29:34 PM
Thank you Eric, I have downloaded.
rgds,  Gyula
Which file are you referring to?
Regards,
Dact
"Terror hearts out, always;
Terror fabric, NEVER!"
eavogels
Quote from: Dact on May 16, 2008, 11:48:32 PM
Regards,
Dact
It's the PDf: How to manufacture............
But I don't think it is the same a the fan motor. Does not look like it.
It's more t?he V-gate, that didn't work in a closed loop setup.
Eric.
xnonix
What makes this model to spin is the custom force field that is aplied and the error on metrics.
Let put the force field to OFF ant then lets increase the accuracy of the model... It stops, there is a stick point and no umbalance...
I'm goint to investigate some more with this curves approaches.
xnonix
xnonix
Hmmmmm,
ok I have investigated a bit, let's see what I found.
* I made my model without setting any force field and putting out the gravity.
* I set electrostatics on to simulate magnets.
* I put a magnet near the fan. Depending on the position of this magnet the system works or not.
* All is made with standard materials in the program.
* Error metrics are minimized in this model to make it more accuracy than standard accuracy in the program. There seems to be no gliches like subit forces made by error metrics.*
* The system accelerates by itself reaching a terminal velocity depending on air resistance (what is set to 0.3). The system works with higher values.
What do you think? A bit strange, no?
Mandatory picture and model
Dact
Quote from: xnonix on May 20, 2008, 03:42:48 AM
xnonix
Thank you, Xnonix, I was hping you would respond. The values I gave to the external force field were not based on any real knowledge of the accurate values proportional to what may be realistic, only on equal polarities. My theory was only based on an observation from deep in the past, coupled with a certain belief that only a manipulation of the components could produce a positive result. I thank you for your interest and input!
Dact
