Free Energy Revealed - Magnet Battery
Started by 0ne, May 25, 2008, 09:14:52 PM
Tinker
sirmikey1
Tinker,
  At 2 minute and 30 seconds, you mention a piece/slice of
hot glue, and so I just wanted to bring that into the equation.
Mike
Tinker
Quote from: sirmikey1 on August 13, 2008, 05:14:40 PM
Tinker,
Mike
That was a piece of hot glue I cut off and used for a spacer to keep the neo stacks seperated in the AL rail you can't see it in the vid it was not used as an adhesive.
Be Well
Tinker
captainpecan
Okay, forgive me if my questions have already been answered, as I'm new here and I tried to read the whole thread to catch up, but it was taking me forever and after page 2 all the bickering was getting a bit old so I skipped to the end.
@ One, and anyone who actually owns U shaped magnets... My magnet supply kinda sucks, but I have gotten small results from tiny neo's and from ceramic magnets.. best so far was only about 20mv, 0 amps. I do not have any U magnets as that is obviously where the best results are coming from so I do not have a way to test for myself my following questions:
1. Have you tried attaching some neo's to each pole of your U magnet, then the dielectric and the keeper? In theory, it seems to me it would add to the magnetism increasing the voltage, while still effectively making use of the U shape loop. Just curious if anyone has been able to jump the voltage this way or if my brain is malfunctioning again as it usually does... lol
2. I did not see where anyone has commented at all about your method of recharging a U magnet with the two coils? Does it work? Because I was wondering what would happen if you introduced a low voltage, high amperage into the coils around the magnet? Would you end up with a nice voltage finally combined with amps allowing you to use it?
sirmikey1
This thread led me over to the Testatica device, reading, and I'm seeing that they
take the original static voltage and split it off into several different power building
devices, some in series, to build power/amps.
Scroll down on this link to FIGURE 7, read the details/construction materials.
http://www.rexresearch.com/testatik/testart.htm
SM
