Free Energy Revealed - Magnet Battery
Started by 0ne, May 25, 2008, 09:14:52 PM
lostmente
ppl!
stop messing with the field!
theres only so much of it, if we all started using it for power then earth would not react kindly
resonanceman
Quote from: lostmente on August 02, 2008, 09:46:38 PM
ppl!
UUUmmmm    do you  mean the earth  will  start warming  up  or something like that? ........or  maybe  some of the  forms of life might  start  vanishing .
One  thing I am totally  sure about .....................if we  do nothing  and just trust the powers that be to work things out, life as we now know  it  will  be over for most  of us  in   20  to 50  years ....
What kind of life do you want for your kids and  grandkids ?
We  will be  tetering   on the edge of  WW3  as long as  oil  is  our primary  fuel .
Once  a  better form  of  energy gets to the people  the mid east  will  revert back to simply  being the  birthplace of  some major  religions ..........as it should be .
gary
Koen1
ppl!
What field? You're not one of those McTaggart fans are you?
Quotetheres only so much of it, if we all started using it for power then earth would not react kindly
Yeah right... nonsense. The earth doesn't "feel" anything when we play with small permanent magnets...
If anything it should be the magnets that get depleted, not the earth...
If we were to build a bunch of huge homopolar generator setups on the equator that use the
earths rotation as driving force, then we would be "braking" the earths rotation while producing
electrical output. But they'd have to be huge and quite a lot of them to actually have any
significant effect.
If we build a small one and spin that, it has zero effect on the earth. But we do get output.
kaworuweb
A direct examination of whether magnetism does matter is, simply DE-magnetising the U-magnet.
1) First, measure the volatge / ampere with you set-up.
2) Demagnetize the magnet by hammering it, heating up or specialized AC demagnetizer.
3) Measure the Volt/ Amp again. if you get similar result, then surely it is busted.
ps. you are better to polish the magnet  twice ( b4 step 1 & 3 ) if you are going to set it on fire  ;D
sirmikey1
Has anyone tried putting several in a series in order
to measure amperage and watts capacity? How does
it compare to a normal D battery?
