Free Energy Revealed - Magnet Battery
Started by 0ne, May 25, 2008, 09:14:52 PM
0ne
Quote from: TheOne on May 26, 2008, 09:46:27 PM
I believe I know why it is not working for me, I have like 1lb of silica gel lying around in a desk, enough to dry the air in all my appartment, so all my paper are 100% dry, no humididy at all, its maybe why it is not working.
I have tried to wet the toilet paper and now I am getting a very low voltage around 2 mv with my sphere magnet, so I believe they are no usefull use of this "technologie" at least in my appartment lol.
I am very disapointed at your pathetic attempt at recreating a Magnet Battery. Almost believe you didn't even try. Well, guess you have no reason to post here anymore then.. see ya.
TheOne
I try and it not worked, stop attacking peoples trying to experiment your thing.
IT IS NOT WORKING FOR ME, its not my multimeter, its not my metal piece, its not my magnet.
You are pathetic by attacking me and I believe everyone from this forum will see that you are pathetic not me.
resonanceman
CHILDREN
Can we stop the name  calling ?
There  will  be no  progress made  in this  thread if it degrades into petty bickering .
@The One .......... are  you really using a sphere  magnet?
I thought  it was clear  from the start  that  to get  the best affect  a U shaped magnet  is best  .
I would   think that   of  all the possible  shapes a sphere magnet  is probably   one of the worst for this particular application  .
@ One
You have  said   that  you think   this  can  be taken  further ...... can  you   explain more about  your  ideas on  how it can  be  imporived?   Or  how to take the next step ?
So  far I  havn't  got  any real power ........and  only  about  .023 V
I have been  playing  with  a  old  18 V  battery for my drill.   I found out  last week that it  no longer holds  a charge .
After  sitting a month or so it  was down to 2.4 V     I had hoped that  this little  battery  would be enough to keep the charge up  and  maybe  have a little reconditioning  effect ......... it is not  quite that   strong ......but it  does keep the  charge  from falling as fast .
One thing that I noticed  is that once  it sits for a while  the  magnets do seem to charge  in some way .
When I dissconnect  the  18 V  battery the  magnets  quickly  drop to  about  .5 V  then  the drop seems to slow way  down ......  by the time it   reaches .2 volts  it is  dropping   pretty  slow .
Just  tapping  the  battery contacts  the  magnet  voltage seems to  jump  up fast  and  drop  quite a bit slower than it rises .
Maybe  this effect  can be useful
Oh .............the set up  I am using is  a set of   disk  drive magnets  on a each side of  a spare  coil of  soft  iron wire .  .....using   canvas as dielectric.
gary
0ne
Quote from: resonanceman on May 26, 2008, 11:29:30 PM
@ One
gary
Ok im sorry for my attitude, I am a little on edge, and I get frustrated when I see negative results from your Magnet Batteries that aren't designed the way I planned.
Is there ANYONE who has tested a U magnet besides me?
There is a HUGE difference when it is ONE U magnet.
Sphere magnets, cylinder magnets, bar magnets, and square magnets all have their "neutral" spot in the exact center of the metal, and the circulation is from the middle traveling outwards. In a U magnet, there is no "neutral" spot, and the circulation is around in an outer ring. The magnetic force from the U magnet is also trapped inside when enclosed with a "keeper". You can not do that with other magnets.
With experiments, I found that the stronger the magnet, the higher the volts/amps. But, even my strongest magnet didn't compare to the U magnet's strength, and the U magnets are really weak.  So this is evidence that the U magnet is the best setup, which was my MAIN DESIGN FEATURE.
I only said you can TEST with other magnets. The U magnet aspect is what you should really test.
About "The Next Step", I'm certain the next step is for people to learn to acknowledge new theories from others. It seems people don't want to discover anymore, they just want to recite books they read and trust with their heart like a Bible.
0ne
