Pushing it!
Started by broli, May 26, 2008, 11:31:23 AM
Seeing as though pushing something around requires a lot less work than bringing it to a higher potential I thought of an idea.
http://broli.dommel.be/slidewheel.avi
Basiclly the video shows the rods beinging pushed at exactly the right moment to disbalance the wheel. The piston IS driven by a motor, but my logic tells me that I can get more power out of the bigger wheel than I need to drive the piston. Two questions arise. Also do note that weels can be used to easy the friction.
1) Do I indeed get more power out of the bigger wheel than I need to drive the small one?
2) At second thought there is no second question. It had to do with the synchronization but that shouldn't be a problem.
AB Hammer
@broli
Interesting concept. Timing to keep from jamming might be a problem. But you don't need it to run a gravity wheel, even though it looks like it could work as an OU design but you need it to shift quicker to get enough energy built up. Heck I just had my thumb nail nearly tor off from my wheel, and I couldn't be happier. Another prime mover design.
Alan
edelind
It may be OU if you use proper rollers. Anyway, the synchronization could be a real problem in your design, as the speed will most probably increase. Maybe it's easier to use magnets and electromagnets which will synchronize electronically (magnets on bars' end and electromagnets instead of the piston). Or, to avoid the vertical friction from the bars and the push piston, to use magnet balls, pushed toward the pistons by an electromagnet.
Just some thoughts...
Alexioco
Quote from: broli on May 26, 2008, 11:31:23 AM
Nice thinking Broli, I enjoyed watching that, quite interesting, maybe the wheel and piston could work with each other, perpetuating itself...
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Oke instead of starting a new thread I decided to just expand on this one with a different idea on almost the same model.
http://broli.dommel.be/slidewheelV2.avi
The idea would work as following. At 12 oclock a stretched locked spring attaches to the rod and then gets unlocked. This will cause the spring to retract pulling the rod with it till almost 10 oclock. Then a lock sets in and afterwards the rod gets deaatched using maybe another smaller spring( or again a synchronization method  :P). The spring returns to it's horizontal position and the process repeats.
Of course friction can be the evil doer, there's a 50% chance of succes since in the good case the wheel will start to accelerate and you're home free. or fricton will not make the spring pass the locking postion in order to repeat the process.
