URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
ashtweth_nihilisti
Here you go guys, a complete research paper with all your hard work on the water spark plug, Aaron, PL, ossie's and many more.This is like a digest so you wont have to goto through many forums posts, it can be periodically updated, just send me the stuff.
Goto the panaceauniversity: http://www.panaceauniversity.org/  Over unity research papers ->Ganga Shakti -Water Spark plug research (PDF)
Ash
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.geocities.com/glorybangla/cqtes.htm
magneto_DC
Quote from: plasmastudent77 on July 25, 2008, 12:28:34 AM
According to SR1, it seems that the 110V DC is *not* what burns the water, rather the ignition spark does - but his circuits appear to have the coil current up to 10 Amps, which at 50 KV is quite a boot.
Hello plasmastudent,
what exactly do you mean?
s1r had a connection from each distributer point to the 8 relay (and to ground) to open exactly only when firing.
But how did it fire? From the same point on dissi with a seperate wire to centre electrode of each spark plug?
So, he got a parallel circuit after each dissi point? (HV-coils in relays?)
Or in series dissi point to relay coils to spark plug centre?
(Or two dissis? Guess, NO.)
Where are the 10A, 50kV?
Thanks
magneto_DC
alan
Why not take a step back and reexamine the Graneau papers?
Ashtweth just posted very valuable information on the panacea website, thanks!
goldenequity
@ Ash
Well done man! Thanks for your time, dedication and skills to organize/develop/distribute such a document!
@ Luc / Stephan
Suggest a download of this .pdf is created with an overunity download link for it at the front end of this thread.  ;)
Rocr
Quote from: Camion on July 23, 2008, 01:25:15 PM
Has anyone tried using a nebulizer to create a water mist?
I was just doing a drive by lurk and thought of the same thing except mabe using an ultrasonic water fogger
http://crafters2000.stores.yahoo.net/ulfog.html
that may give you the finest mist for the buck..  I was looking at them for a gasoline vapor carb idea ?
maybe take it apart and rig it in a pvc tube container with a cap cut as a venturi for intake control to experiment with ... ?
Good luck guys
