URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
AhuraMazda
On multiple discharge:
If you want to discharge the capacitor 3 times, you will have to be very quick to charge it up.
I don't think it is practical.
My proposal is to charge the 3 capacitors prior to reaching TDC and firing them at desired intervals.
This puts heavy demands on the circuit design.
gmeast
Quote from: insane4evr on October 05, 2008, 10:05:08 PM
Hi gmeast,
Thanks for your average current draw calculation. Since the way I understand your circuit, all power comes from the inverter, can you measure inverter current draw from the battery to compare it with the calculation? I am not sure if it will be pulsing or will be filtered by the inverter internal capacitors, etc.
Hi insane4evr,
I have taken the measurement with an analog amp meter and here are the results with final calcs in watts:
First the pulse power calcs again:
5,000 Rpm = 83.33cycle per sec.X 4-Cyl / 2(for 4-stroke engine) = 166.7 pulses per sec
12.5 ohm current limiter to Mosfet through 134V (charge) = 10.72 A
scope says 2.5 ms per pulse charge but it's a 'ramp up' = 1/2 = 1.25 ms per pulse (ave)
so ... duty cycle is 1.25 ms/pls X 166.7pls/sec. = .208 (this is now dimensionless factor)
therefore:
10.72 A X .208 = 2.234 A
looking at the capture from the scope (1st photo below) it resembles a sine wave somewhat, so we can use 0.707 X 134V in the average power calc:
.707 X 134V X 2.234A = 211.6 Watts.
Wp = 211.6 W
Now,
the alternator was putting out 13VDC
the analog amp meter (2nd & 3rd photo below) read 16 A
13V X 16A = 208 Watts
Wi = 208 W
and Wp agrees pretty good with Wi.  Compared 211.6 W to 208 W.
Peace,
Greg
happyvalley808
@gmeast,
Thanks for doing the math...
So a smaller inverter wouldn't work ?...... the inverter has to be 400w or more ?
Thanks for your time..
Mahalo Nui Loa,
HV
Chris31
Quote from: AhuraMazda on October 06, 2008, 03:59:45 PM
Hi
I was also thinking something along that line, well I though using 3 set of CDIs might do it. Each capacitor is charged in turn such that the load on the inverter is spread throughout each revolution. Then the 3 capacitors are discharge sequentially within let say that 10 deg.
I dont know if its beneficial or not, I wont bother with it at the moment.
insane4evr
Quote from: gmeast on October 06, 2008, 04:11:43 PM
Hi insane4evr,
Peace,
Greg
Man you really know your stuff. And a mathematician even.
Thank you very much.
