whopper1967
I could be wrong,but i thought he said he only used to batteries because when cranking starter it tended to kick out inverter due to starter drawing amps.
qiman
Great job Gotoluc and Ossie,
Check this out:
http://www.youtube.com/watch?v=l54wlbi0Szk
Not sure if you agree with the explanation, but the electroradiant event you have is fragmenting the heaviside flow away from the conductive wire.
Take care,
Aaron
resonanceman
Quote from: bumfuzzled on July 04, 2008, 12:37:51 AM
I just remembered, S1R said something in a post a long time ago about using a seperate battery for the inverter. Maybe this is my problem, I need to isolate it. When I blew both of those inverters it was like it was feeding the 110 back into the inverter on the 12volt side. I have no trouble at all with using mains power and a rectifier, well not until today. I hooked up the primary side of the IC to a distributor I had laying around and was gonna use that to pulse it but when I hooked up the 110 to the circuit all hell broke loose. It blew up my rectifier and kicked the breaker. The distributor was laying on a metal table but the rest of the circuit was insulated. I guess it fed back thru the drill press that was on the same table somehow. This is why I'd like to know exactly how this circuit works, I mean the flow path of the electricity.
It  could be that    your   inverter  was  grounded somehow
If you  remember   S1r    made a point  of  explaining that the   inverter and I believe the  relay box had  to be insulated .... the only  point that the  inverter circuit  connect with  any other  circuit is  at the spark plug .
gary
gotoluc
Quote from: bumfuzzled on July 03, 2008, 11:37:30 PM
Blew up another inverter! Soon as I turned it on. Also tried a different ignition coil and still have to reverse the polarity on it to get a HV arc. I'm lost. It doesn't help that I don't understand exactly how the circuit works or that I don't really understand electronics that much so until somebody comes up with a fool proof circuit I give up!
Hi bumfuzzled, which circuit are you using?
At everyone, I have posted this before but I will say it again since some don't read all my posts. Look at the first page of this topic again. I have updated it and my circuit. You need to re-read page one since there are many text changes which can help you.
Luc
callanan
Hi bumfuzzled and all,
I understand that many may be eager to attempt to start building these circuits to test them but I must stress that unless you understand how they operate, as well as have some experience in building and testing electronic circuits, it is likely to be an expensive and possibly also dangerous excercise for you. So please understand what you are building and how it works before you proceed as there are many traps for the inexperienced.
One these traps that is most likely the cause of people blowing up their all solid state inverters is that the HV pulse from an ignition coil can be either positive or negative. In all of my circuits, the ignition coil pulse is always positive. But in practise, it can be either.
To accommodate this you will need to make sure your inverter's input and output is isolated fully from the ignition coil circuit. There must not be any common ground connections. You must then test the polarity of you ignition coil's output pulse by using a long string of LV diodes or some HV microwave oven diodes, preferable 3 or four in series, to prove if the HV pulse coming out of your ignition coil is negative or positive. Once you have proved this, then when you connect the output of the diode string from you inverter circuit, you will connect it to the spark plug positive if your ignition coil pulse is positive or to the spark plug ground, if your ignition coil pulse is negative.
Ossie
