forest
This coil is surely generating so called RF or better radiant oscillations in low voltage flow wires. This field is a cause for water ionization and because HV spark is slowed it has a time for doing it.
lasher23
I don't want to post anything irrelevant, but has anyone messed with using a flyback transformer and drive circuit to produce plasma in the plug? I only ask because the plasma seems to be a necessary part of these experiments, and my flyback setup produces it consistently....at least it seems to. Let me know if this is a useless way to drive my plug.I may have missed something.
plasmastudent77
Hi Ninjadaniel
I will be trying to do the straight rectified AC and see how we go.
One thing I have done too is put a BIG 1/8 inch ( 3mm ) earthing cable from my work bench to a steel earth stake I have driven into the ground outside my shed at home. The idea is if anything goes bang, I'm not the path of least resistance for the current, especially when you are dealing with DC. DC is nasty stuff.
Btw - I'm not lecturing, just mentioning a few safety features that others might consider.
qiman
Hi Luc,
Here is a good tutorial I shot at Peter's shop yesterday just to get someone going on the basic circuit if they're just joining your thread here:
http://www.youtube.com/watch?v=wlMELbK8zDQ
It has schematics and photos. Easy circuit to isolate power supply and ignition coil.
What was the exact inspiration to make you put the diode from the cap to the HV on the ignition coil?
Park34
Quote from: k4zep on July 16, 2008, 01:01:06 PM
Hi Gang,
Did a very loose test of S1R's coil setup.  Green is 5 turn HV, Large black is 7 turn modulating coil, small red to side is pickup.
NO combinations of wiring on the black and red in the magnetic circuit caused ANY change in a normal spark from 1 Hz to 1KHz spark on the plug.  This is not to say it does not work, I just am unable to see any change in the spark or ANY change on the pickup coil on a scope....NADA.......I know it is not exact, was not looking for a "Kaboooooom", but not even a twitch on scope or in spark.....with high current in secondary coils.
Ben
excellent use of a clamp if i do say so :)  just curious is that really the way itys hooked up, i am seeing allot more ends of wire with your setup 2 red 2 blue and anohter 2, with s1r i am only seeing 3. just curious
thanks
