fget2a
Quote from: xbox hacker on May 26, 2010, 08:42:48 AM
@fget2a
Nice demo  ;D
http://www.youtube.com/watch?v=FksWsEb7zig
@Luc
I'm still lurking in the shadows...lol
i use home built cdi ignition system, for "HV" side...  30 KV
i use cap70 similar "Voltage-amperage mixer coil" elektrical circuit.
without "mixer coil" no exploding water on open air.
in engine working little effect of exploding water.
if my without mixer coil, then no little effekt in 250ccm Yamaha engine.
there is a problem "voltage leaking".
fget2a
Quote from: xbox hacker on May 25, 2010, 04:13:24 PM
LOL....not accurate?
Thats my design, my site...it does work! :)
The only problem was prolonged diode life and voltage leakage....
JULY 5th 2008!!!
http://www.overunity.com/index.php?topic=5024.msg110213#msg110213
seems like a lifetime ago....
"Voltage leaking"
amperage is possible leaks. If it continued, the LV circle. it takes more than a small engine with water-2000mF 4000mF?....
hmm.. possible??? ???
HUMPHREY
I have tried the first circuit with a chevy igniton coil from a distributor cap. There is a small spark when the diodes are disconnected, but when the diodes are connected it seems to be shorting across the diodes. Could it be the ignition coil?
gotoluc
Quote from: HUMPHREY on May 29, 2010, 12:59:52 PM
If the coil can make a spark then it sounds like it's working. It sounds like the HV of the coil is making its way to ground through the diodes. I would check each diode to make sure each one is good. You should have a minimum of 10 good Diodes or more if the coil's HV is weak. I also recommend using 1N5408 as they are rated at 1000 volts 3amp each.
All the best.
Luc
altenergyshift
