0 Members and 77 Guests are viewing this topic.
Michaelpier
Thank you lon,thats why my relays (60Amps) always freeze from the small sparks ? I will try with the inductor to see if i can eliminate those.
QuoteWhy don't you just use SCR instead?
Can you suggest one?
Have in mind that my supply is 230ac to 320dc.
lon92
No problem...  ;D
Could you give me the part number?
Or, better yet, you could check the datasheet of your SCR at http://www.datasheetcatalog.com/.
Or, maybe, if you could, just Google - (CDI Circuit).
http://www.sportdevices.com/ignition/ignition.htm
Michaelpier
The inductor works fine. Finally is working, especially if you spray some water :D
I think i will pass the scr for now.Thanks Lon.
Now i must think what to do with it   :P
lon92
Glad it works!  ;D
Let me know when you got the idea... Lol!
diehostusxana
Hello guys out there :)
I'm back, have now motor (100EUR :) ), have now read the paper www.panaceauniversity.org/Water%20Spark%20Plug.pdf
that doc is simply great, superideas. Supergood autors.
I have bought a simple 1-Zylinder 4-Takt motor.
And I want to make it run with plazma spark for testing.
Could anybody suggest, how do I convert "Magnetic Pickup" inition to Plasma, without external power supply?
.) Case1: may I with original coil impulse charge some condensator and later just discharge it through external coil of CDI ignition?
.) Case2: charge with external battery 1x Cap of 200V, 1uF and put in parallel to sparplug
.) Case3: ideas?
Here my picture:
