Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
Grumpy
Link to article on Hubbard coil:
http://www.rafoeg.de/20,Dokumentenarchiv/10,Personenbezogenes_Archiv/,Hubbard_Alfred/The%20Hubbard%20Energy%20Transformer%20by%20Gaston%20Burridge.pdf
Distruibutor was for 8 cylinder - shown in image on page 2
11.25 kv dc shown in image on page 3
I believe a space heater is shown on the left.
He would only run it for short periods of time due to overheating.  Output wire may have been to small of gage.
        -Frank Edwards
z.monkey
Howdy Y'all,
Grumpy and Paul, the Hubbard Coil is supposed to a SELF Sustaining Electrical Generator.  It develops and sustains its own power without external drivers or being continuously connected to batteries.  The idea is the coil is inductively self resonant and it puts out power with no input.  I spent years trying to drive this coil in anyway possible.  Pulsed DC, AC, Capacitive Discharge, High Voltage.  The main reason it didn't work was the coils were not connected in a loop.  It was beyond my reasoning to connect the coils in a loop.  I had to look at it a totally different way.
When I saw GiantKiller's coil go into resonance it clicked in my brain.  His set of air coils does this because you have a full cycle of a sinewave represented in a set of 4 coils.  Basically when the voltage finishes traveling around the loop it is in its original phase at the same voltage and frequency.
This allows it to continue traveling infinitely.  This will work in increments of 4 coils.  GiantKiller's 4 coil set is one cycle.  My Infinity Coil is two cycles, 8 coils.  This is why you guys have so much trouble tuning the TPUs.  The TPU only has three drive coils.  They are usually driven with three different drivers.  That makes it tough to achieve resonance.  Plus you only have three phases represented, not a whole sinewave.  The all inductor Hubbard Coil achieves resonance by it own nature.  The physical characteristics of the inductors define a resonant frequency, and the device only runs at it its own resonance frequency, hence no tuning problems.
The Hubbard Coil is a true power oscillator.  The trick is using coils in multiples of 4 and connecting the coils in a series loop with all the windings in the same direction.  You have to pay attention to the way a sinewave and an arcsine wave move around this thing.  This is an Alternating Current Device, and the only way you get it to put out power is to let it resonate by itself, NOT driven!
Also, yeah, No Caps!  This power oscillator makes an L4 or an L8 circuit and NOT an LC circuit.  Any capacitors in parallel with any of the coils will throw off the resonant frequency enough to cause the device to not oscillate.
Blessed Be Brothers...
Goodwill to All, for All is One!
Grumpy
Did you ever replace the iron cores with magnetized cores?
What you describe is a "ring resonator" and they are not OU.  Not only that, if the Hubbard device is a resonator, it would be a longitudinal one since the coils are sideways.
The hubbard coil can be self-sustaining via the method I suggested.  Notice that it is an open ring, rather than closed like a TPU - Safer this way.
If you think EM induction is that only way anything works, then think again.
Caps are not required when exciting a coil to emit RE with inductor discharge, or constant current (i.e. DC) source.
It is not alternating current - it is "pulsating" - huge difference.
Quote from: z.monkey on July 14, 2008, 07:26:08 PM
Howdy Y'all,
This allows it to continue traveling the infinitely.  This will work in increments of 4 coils.  GiantKiller's 4 coil set is one cycle.  My Infinity Coil is two cycles, 8 coils.  This is why you guys have so much trouble tuning the TPUs.  The TPU only has three drive coils.  They are usually driven with three different drivers.  That makes it tough to achieve resonance.  Plus you only have three phases represented, not a whole sinewave.  The all inductor Hubbard Coil achieves resonance by it own nature.  The physical characteristics of the inductors define a resonant frequency, and the device only runs at it its own resonance frequency, hence no tuning problems.
        -Frank Edwards
Grumpy
One more thing:
Impact excitation (i.e. electrical vibration of an inductor) causes the inductor to vibrate at it's own resonant frequency regardless of the frequency of the impacting impulse.  So, the hammer and the tuning fork are separate and that is what Tesla was doing.  The resonant rise stuff was just a means to get a higher voltage.  He stated much later when that resonant rise was not the best way to achieve this.
EDIT:
Oh, and it could be driven or looped and still be over, so what does it matter?
        -Frank Edwards
z.monkey
Howdy Grumpy,
You have to look at this thing in a different way...
Tesla defined alternating current theory, and I have seen it resonate with a sinewave.  The reason that the ring oscillator will work is not magnetic induction alone.  The wave running the peripheral coils is "pulsating" via alternating current.  The magnetic fields are spinning around the central core.  This produces a vortex in the center coil, increasing the flux density and increasing the energy traversing the coil.  Ordinarily the back EMF from a coil is less than the initial energy put into it.  But in this case the vortex produced by the spinning magnetic coil pulls more energy in from the surrounding environment.  This produces a power gain in the center coil which is inductively coupled to the peripheral coils.  This increases the voltage in the peripheral coils, sustaining the device.  The core design is the key to the magnetic vortex.
