S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
Park34
Hi bruce,
nice to meet you, pardon my stupidity but the, i am using an inverter i am not using an inverter is confusing me, in your opinion is an inverter used?? and if so where is the hookup on your diagram, and from what i am understanding he used to attach a ground to the plug but the "newer" examples do not have such grounding, i realize your uses will be different just curious on your opinion
Bruce_TPU
Hi Park34,
Xboxhacker has the coil hookups correct on his last diagram on the last post of page 3.  Correct that is according to the .pdf.
If it were me trying to make this work, I would have the 12volt steady bias exactly where it is called for, and then use what was needed, to pulse the ignition coil with very high voltage on top of that bias.
One other interesting experiment would be to raise the low voltage bias from 12 volts to say 100 to 200 volts, and then fire the ignition coil using whoever's circuit, on top of that.
And then, just for the fun of it, I would put a pickup coil, one near this S1R coil and a second pick up coil near the plug, or put the plug in the center of an aircore toroidal winding and see what I can see.   ;) ;D
And then, if I were really want to feel the RE, I might even wrap another bias around the plug with the toroidal winding, with North facing up....hmmm...but that is just me of course.  I don't know better.  ;)
Cheers all,
Bruce
xbox hacker
@Bruce,  I am just curious , but isnt the "bare copper coil" with a nail in it going to be a dead short, and the HV will take the path of least resistance, and possibly not "follow" the path if the actual winding?
BTW..the image in page 3 is the same on page 1....
Park34
Ok becomnig tired but doing research and have a few questions / ideas
Found my old lawnmower, cleaned the carb and got it running on gasoline
ok first off about the s1r guy
if you can run an engine on water why mess iwth wood gas which he states on the yahoo forumn
what is causing the air bubbles in the bottle they are holding, if it is the suction why not put a hole in the top, or by not ahving a hole is this providing enough fuel.
why just run a hose in the intake/carb, why not run it thorugh the float bowl, thus atomizing it and i would imagine it would burn better,
ok now onto the research i did
what i am finding he made is a step up transformer, what i am confused on is the fact the it would step up to voltage not the amperage, and what i have beenr eading from you guys you want more amps at the plug.
I cant figure out the point of the winings on the 12 volt wire around the HV coil, since there are more turns of the secondary than primary it would also boost the voltage to that line i would imagine, woulnt not having this coil make it so you dont need the lamp??
bumfuzzled
He says LOTS of things that don't add up
The bubbles are from the suction on the bottle. If you put a hole in the top the water would just pour out uncontrollably. What would be better is a needle valve inline with a hole in the bottle, so you can adjust the mixture
Could be that it needs a very rich mixture, basically flooding the engine.
Don't know much about electronics but the way he has the 12v side hooked up by the way he describes it it's basically a dead short to the battery, thus you need some kind of current limiting device. Personally I think this coil is pure BS but a design similar to that might work. Check out the other water for fuel thread, Ben posted an interesting piece on a 3 coil transformer on page 24.
