this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
nitinnun
i'm talking about magnetic spin, which is similar to what atoms themselves generate.
the diamagnetic and the electron fields, of each atom in the universe.
the diamagnetic field IS clockwise spinning magnetism.
the elecron field IS counter-clockwise spinning magnetism.
when you mix these 2 magnetic spins together, they create a completed magnetic field.
a magnetic field, which can be turned into electricity.
amigo
Les Brown's theory is that everything is magnetic (whatever that means to him) and so light, electricity, magnetism, etc. are all products/manifestations of the same Universal force. Something like when Leedskalnin's says there are tiny magnets inside each magnet bar for example, those tiny corpuscles really not being magnets at all but a more primordial force.
To use old terminology, I believe it to be an Odic force or Odic current, or simply Od, as named by Karl von Reichebach back in the 19th century. If you look at some of his writings here: http://www.hbci.com/~wenonah/history/odenergy.htm you will read that certain people (sensitives) could see force emanating from permanent magnets, a subtle force that is. Same with crystals by the way, just more powerful it seems, as crystals act as foci for Od.
In any case I lean to think that the same effect occurs in pyramids and other "sacred'" geometries, where this primordial force gets to express itself. And it's the very same thing everywhere else, just people give it different names or try to explain it with different means.
nitinnun
a magnetic field, causes electricity to form.
and electricity causes a magnetic field to form.
i think that a magnetic field could cause ALL forms of energy to manifest.
if you modulate it correctly.
and likely that all forms of energy, cause a magnetic field to manifest.
even heat, gravity, sound, and light.
that is why a strong enough magnetic field, will contain heat
or lightning.
or even inertia.
they have working fusion reactors, that retain extreme heat, with their magnetic fields.
just ask doctor octopus.
some suppressed devices, reasonably explain the old legends about magic and wizards !
Koen1
Quote from: nitinnun on January 08, 2009, 12:10:36 AM
Well more precisely, a change in the magnetic field intensity gives
rise to a brief flow ( aka "current") of electricity.
And a flow (or current) or electricity gives rise to a static magnetic field.
Static magnetic fields do not give rise to electrical current,
nor do static electric fields produce magnetic fields.
Quotei think that a magnetic field could cause ALL forms of energy to manifest.
What do you mean by "all forms of energy"?
You mean all forms of energy that are considered unrelated to electromagnetism?
Can you give an example of such an unrelated energy form?
It seems to me that every form of energy we know is already known to be conveyed
via photons, as in the current model photons are the only particles that can actually
carry and transfer energy. Since we know that photons are a form of electromagnetic
radiation, it seems obvious that all forms of force and energy interaction must have
an electromagnetic component.
Doesn't it?
So what are you saying exactly? Or is this exactly what you're saying? ;)
Quoteand likely that all forms of energy, cause a magnetic field to manifest.
Well... that's partly what I was trying to say above, that brief electric flows
(or pulses or bursts or oscillations) only give rise to a magnetostatic field
when the flow is present. When the flow alternates the magnetic field does so
as well, and then we no longer have a simple static magnetic field but we've
then got waves. And yes, every electromagnetic wave always has both
an electric and a magnetic component. But neither are static electric or magnetic
fields, they're alternating and interwoven fluctuations of electric and magnetic fields
in motion through space.
I get the impession you're just saying that every electromagnetic waveform we know
(heat, light) has a magnetic component, and that's a well known fact.
That gravity has an electromagnetic component would seem plausible in the light
of the electrogravity and Townsend Brown research, although the exact relation
is still unclear and it might just be that electrogravity effects are "rough and brute-force"
methods of altering the local energy density of space, which would relativistically
speaking have an effect on space-time itself and very possibly on the curvature of
the local space-time region.
Sound, I thought was proven quite conclusively, is solely a pressure wave phenomenon
in the medium. If the medium contains many charged particles then specific sound
waves could indeed produce specific electromagnetic fluctuations.
But sound waves causing magnetostatic fields seems quite difficult...
Quotethat is why a strong enough magnetic field, will contain heat
Really? Interesting. So you believe that we can create a strong magnetic
field in a vacuum chamber and if we stick a thermometer in there that does
not react directly to the magnetic field (so it's not magnetic, not inductive, not
conductive, etc), we will still measure high temperature?
Or do you think that would only work in an atmosphere?
... strange idea, that a static magnetic field would generate heat.
Quoteor lightning.
Or lightning, indeed. ;)
Quotethey have working fusion reactors, that retain extreme heat, with their magnetic fields.
Correction, "they" use the extremely strong magnetic fields to contain a constant circular flow
of highly charged and high temperature plasma. Not "heat". Plasma can be contained
using magnetic fields if the fields are stong enough and the plasma moves. It's a sort of
"magnetic bottle". The plasma is a collection of charged particles and the "containment ring"
is also partly a particle accellerator. It is not so simple as a simple static magnetic field
creating heat inside it. It is the huge amount of energy delivered by both the initial "pumping"
and laser-compression fusion that causes the plasma which contains and causes the heat,
and it is the moving plasma that is contained in a circular flow within the strong magnetic
containment "ring".
Quite abit more complex than just a static magnetic field that causes stuff to heat up.
Quotesome suppressed devices, reasonably explain the old legends about magic and wizards !
Lol now there's an interesting remark :)
Can you name a few?
And quite a few non-suppressed devices would also seem to be magic to ancient people.
Just imagine how ancient Romans would have reacted to a Taser Gun or Tesla coil? ;D
nitinnun
koen1.
why is it that your brain can find so many words to type,
yet cannot make any of them constructive ?
are you aware that most of your words hold no research value what so ever?
or value of "any" kind ?
here i am, exploring the depths.
of mysteries unknown
there you are, attacking my air supply with a hatchet.
convicted to the doctrine of the mundane.
by the way, koen1
congradulations for being the first user to give me a negative karmic vote.
it was heavily symbolic of your normal activities.
to condemn others.
