Pereptual Motion Wheel
Started by Alexioco, July 21, 2008, 02:30:28 PM
Alexioco
Ok, you all thought that was amazing? Well wait till you see what I have just come up with...
This pure mechanism may have the capabitly not to cause a light weight to lift a heavy weight, but a weight that may even rise itself through its own weight, now how does that sound?
Its going to be hard to explain this even with this picture (I have colour coded it to help)
Here we have the main lever (red) second lever (blue) a presure lever (green) and a second presure lever (black) with a grey weight.
When the grey weight is placed in the presure lever this is what happens.
ps. the green presure lever slides down
The weight pushes the black presure lever down which pushes down on the green presure lever that pushes on the blue lever, the other end of the blue lever pushes up on the red lever which pushes the ball up. You see as the green presure lever is going down the weight is going up :)
Edit: lol it will be very strange if this works because if you took the weight out and pushed down where the weight would be, your hand would be pushed up with more power out than in, you would have to push to lift it haha
You could put another little weight at the far end of the red lever which will lift the large weight up if it doesnt lift itself.
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Quote from: Alexioco on July 23, 2008, 02:48:22 PM
To what is the joint of the black lever attached? To the background or to the red lever?
Alexioco
Sprocket
WM2D would tend to suggest that this won't work...
Sprocket
While I'm on the WM2D theme (again!) - here's a better attempt at the original idea.  Basically allowing the weights to rotate on their individual levers, to better allow the effect of the acting weight to propagate around the circle.  Unfortunately, while it does now require less weight to 'loop-the-loop', it is still needs to be considerably heavier than its fellow weights...
