Mysterious Resonant Circuit
Started by EMdevices, July 24, 2008, 10:04:51 PM
Cool nice going. Did you take the margin of error into account? Also since you claim OU can you not add a circuit that sends the power back?
Bruce_TPU
Hi EM,
Good job.
But...lol... I would like to add, that I discovered some time ago, that using your blocking oscillator for the self  running micro TPU, I could get it to run much longer and much better (brighter), if I had the transistor reversed, if you recall.   ;D
Many claimed it could not possibly run the way I had it, but of course it did.  And for a very long time, if I recall.  LOL  No one paid much mind to it.  I found it facinating.
See the following:
http://www.overunity.com/index.php/topic,3599.msg60203.html#msg60203
http://www.overunity.com/index.php/topic,3599.msg60208.html#msg60208
http://www.overunity.com/index.php/topic,3599.msg60261.html#msg60261
And many more posts.
Cheers,
Bruce
poynt99
what is your voltage amplitude across the 150 Ohm resistor:
17.5V (p-p), (p), or (rms) ?
fritz
hmmm, the fact that the transistor doesn't heats up means
only that the class c osc/amp has a useful operating point
/driving impedance.
Maybe this issue (transistor not heating up but load heating up)
was so often repeated over and over in the Stiffler threads that
it somehow made the way to kind of truth. for whatever reason.
If you have a voltage source and a load - the stuff with the higher
impedance gets hot.
If you have kind of transformer/complex load line between source
and load - you have the same in respect to the transformation ration.
The first transistor radios had every amp stage coupled by transformers
for optimum gain/matching (copper was cheap these days and they
used it from their tube setups.
rgds.
Peterae
Can i ask why there is no smoke coming from your 1/4 watt load resister if it is indeed dissipating 1.02 watts
Peter
