Thanks to ALL for your help!!
TESLA pattend 390721 BUILDERS THRED
Started by innovation_station, August 09, 2008, 11:02:40 AM
innovation_station
Quote from: redstone64 on December 02, 2008, 09:24:13 AM
Hello,
     it's clear that a rotating magnetic field with a lot of speed, will cause some kind of gravitomagnetic effect and energy generation. Since 2 years I follow people who are trying to replicate that SM thing.
    It is clear for that:
1. Rotational magnetic field with very high speed of electrons causes this effect.
2. A lot of high voltage is need for the first start of this device, I don't think 12v is enough, 100v or much.
3. At least three magnetic pulse, i mean vertical magnetic coils.
4. For the output, there should be a very high quality regulator which will collect some energy for back feeding.
   Unfortunately, so many people replicated this device, have tested it with a very low input voltage on coils, it is better to use very high voltages around 100v and 200v to test it, than a reasonable kick can be seen.
   One of overunity threads, I have seen an old TV schematic, which has a toroidal shape, TPU like unit at the center, But I can't find it again. If some body has can you send it?
    A small note: Tesla used lamps during their tests. We are still using transistors, MOSFETs? Those devices are slow comparing to lamps. I think Lindsay had a good reason why she tells this thing.
;D
my cold bottles will remain cold a wile yet ;)
ist!  8)
redstone64
Hello,
I think Large Capacitors on SM's tpu are not for output regulation, they are used for firing collector coils.
IST we are not wile!
redstone64
Spherics states that:
A pulse into a coil generates an expanding magnetic field. The magnetic field comes into being by an underlying patterning of the ether. It is a cascade action on the part of the ether that causes the EFFECT of an expanding magnetic field. If you then cause a second magnetic field to expand through the same space as the already expanding magnetic field, a specific cascading action, a pattern is setup in the ether which is the EQUIVALENT of a magnetic field and has many of the characteristics of a magnetic field. By this I mean it will interact with metals, and cause the EFFECT of a current, IF the field is moving across the metal. I will refer to this field as a COMP field from now on. But please be clear this COMP field is in addition to the expected magnetic field. This COMP field, a patterning in the ether, is dampened and effectively nulled by magnetic metals.
Let's try!
After making tests with the circuit simulator, I can see the kicks covering both peaks. It seems to be the key.
