Just for S#ITS and Giggles...i hooked up an...
Started by christo4_99, August 20, 2008, 01:55:36 PM
christo4_99
to me it's like this:if the voltage goes up while it's running it's making excess power however miniscule it might be.this implies that the more efficient any of the components might be the excess power will go up.if a better motor was coupled to it it would make more power or if the alternator was better it would make more power.if both components were better it would make more power.
gyulasun
Quote from: christo4_99 on August 21, 2008, 06:45:43 AM
Hi Christo4_99,
Basically you sound right but if you expect members here to say with certainty you have achieved overunity then it cannot be done with responsibilty without closing out possible pitfalls.
Batteries are strange and tricky beasts and you sure have heard about sulphations in them that gets disappear when the battery is hit by current pulses and the battery revives.  And from your motor + generator plenty of pulses can hit your batteries, so one way to rule out this possibility is to run severel long term tests with your setup on charging and discharging.  I do not say your batteries are sulphated and that is why you find the battery is charging (when in fact you take out energy from it) I say to make sure it is not the case...
I do think there is an anomaly that makes the battery voltage increase but without a thorough and long test runs I cannot say you have got overunity.  I can only encourage you to continue testing and testing this interesting setup.
rgds,  Gyula
gyulasun
Hi Christo4_99,
I mentioned that some patents include more or less some variants of your setup and now I found them referred to it here in this forum, in a totally different topic aspects though: http://www.overunity.com/index.php/topic,1821.msg32871.html#msg32871
The last two are German text and if you cannot read German you can get free computer translation by clicking first to the Description icon under the title of the patent, then a new window appears and click on the Translate this text icon.
I can only repeat again: after the description of your tests it does sound like you have achived overunity but to make sure about it, long and precise tests should be performed!
Thanks,  Gyula
wizkycho
was it hoked up like that ?
without current regulator on rotor+ or on rotor- ?
If not please draw a schematic, one picture tells thousend words
wiz
christo4_99
Quote from: wizkycho on August 22, 2008, 07:02:38 AM
yes,except for the ignition pin(on switch) and the voltage sensor wire...both hooked to positve
