Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
z.monkey
Howdy Y'all,
I had a bit of a revelation about Super Light.  We have light (energy) coming from our sun which is interacting with the super light coming from the central sun at a perpendicular angle within matter.
The frequency of the the superlight is an order of magnitude or two higher than the frequency of light coming from our sun.
These two sources of energy are heterodyning within the matter and causing the matter to resonate at the difference in frequency which would be an order of magnitude or two (kilohertz to megahertz).
The specific type of matter would dictate how the energy is manifested.
Drannom has said that the Alum Crystals that he grows convert the super light into visible light.
Permanent magnets made with ferrous metals convert super light into magnetism.
The Electrinium would convert super light into electricity.
Heavy elements such as uranium convert super light into gamma rays.
I suspect that the major portion of the lighter elements convert super light into gravity.
If this theory can be expanded then we can find a combination of physical material which can be made to emit any energy in the spectrum....
Blessed Be...
Goodwill to All, for All is One!
resonanceman
Quote from: z.monkey on October 08, 2008, 09:55:31 AM
Blessed Be...
Z Monkey
I susspect  that harmonics  are always present   so  one  atom  may  emit mostly one type of  energy but  it  probably  emits a very wide  range of energy too .
As  far as gravity  goes I kind of like the  explination  in the PDF   Gravity is  caused by  protons  and nutrons  having more ability to block  super light .......so gravity  is   a shadow  in the  superlight flow
This  would also imply  that  the energy that is blocked  would  be emitted  as another form of energy ......so the heavy atoms is  where we are likely to find  usable  energy output  of some kind.
gary
resonanceman
I am  wondering  if this  idea could be a  way to  test the  superlight  theory
http://www.overunity.com/index.php?topic=2157.320
reply 323
If the  superlight theory is  correct  and   gravity  is  the superlight  being  blocked by the  protons and nutrons in the atoms   heating  the  iron  would make  the  atoms move faster .....making  superlight collisions a little  more likely .
I am also assuming that  the superlight  collisions   cause  some energy to be  released in other forms
A heavier metal like lead might  work  better than iron  if all this is true .
it  should also mean that there would be  some  energy  flowing  even at room temp .
I am thinking it  would  probably be radiant  energy  so  it can't be measured  directly .......but it would  show up as  a voltage rise  in the battery
gary
z.monkey
Jeanna, Resonanceman, Drannom,
You are the three here who know about St. Germain, and possibly read the Kybalion.  St. Germain can precipitate elements from the ethers directly.  In the Kybalion they state that Mental Transmutation of elements is possible.  These powers seem like more than we are capable of, but they are not.  I know we can practice the direct precursors to Mental Transmutation with Mental Attraction and Creative Visualization.  Since we are not advanced enough to either directly precipitate matter or perform Mental Transmutation, we can do the next best thing.  Use Mental Attraction to find the materials you want to use, and transform them into the structure you want to build using Creative Visualization.  This will be like mentally forging an alloy.
Mr. Summera says we need pure iron, pure silver, pure silicon, and borozon (boron nitride).  Although the process would be much easier to simple melt these in a crucible we are looking for a lower cost, and safer method in which to transform these elements into Electrinium.  A furnace that is capable of melting silicon and borozon would not be cheap.  So here is the alternative, low cost method.
They say the fire in your mind rivals the fires of hell.  Lets use that fire for a constructive purpose.  Lets mentally forge an Electrinium alloy crystal.  We have to mix the essential elements.  To do that when they are in a solid state is difficult.  We first start by grinding each element into the finest powder possible.  Then we would have to portion the powdered elements into a mixing chamber.  Thoroughly mix all the powdered elements together.  Next we would add the powdered elements to a crucible.  I believe that some heating is required for us at this point, but ultimately this can be done purely mentally.  You want to heat the crucible until it is glowing hot, but not hot enough where the contents turn to liquid.  We want it hot enough to where it is in a plastic state where it can be manipulated physically, except that the manipulation is going to happen mentally.  Take the crucible out of the fire and place it on a stable surface.  As the mixture is cooling you are going to work it with your mind.  Be prepared with the specific molecular structure that you want to grow.   As the mixture is cooling visualize the molecular structure that you want to grow and focus your attention on the crucible.  All the elements that you need for this molecular structure are already in the crucible, all you have to do is mentally arrange them.  As you maintain your focus, and the visualization of the molecular structure, the mixture cools to the point of locking the molecular structure into place, creating a stable, permanent Electrinium Crystal.
This process does require specifically focused mental power, but it is a lot cheaper than buying a crystal pulling machine.  This also eliminates the tedious, and lengthy manufacturing process I outlined at the beginning of this thread.  But it will only be able to be accomplished by people that have honed their mental powers to a fine edge and are able to think with the clarity and persistence that this process requires.
Drannom, try altering the shape of one of you alum crystals mentally.  Grow a sphere instead of a pyramid.
Jeanna, Resonanceman, you have already shown access to advanced mental powers, I believe you could mentally precipitate Electrinium directly.
http://en.wikipedia.org/wiki/Boron
http://en.wikipedia.org/wiki/Nitrogen
http://en.wikipedia.org/wiki/Silicon
http://en.wikipedia.org/wiki/Iron
http://en.wikipedia.org/wiki/Silver
http://en.wikipedia.org/wiki/Alloy
Blessed Be...
resonanceman
Quote from: z.monkey on October 09, 2008, 10:21:52 AM
Blessed Be...
Z Monkey
I do believe that  mind can  manipulate energy  .
One example  is that I call the   Daniel Pomerlou effect .
http://www.overunity.com/index.php?topic=393.0
I believe that Daniel   started making his  devices before  he understood that there was no way that they could work .     They only work  because he KNOWS that they work .
I haven't been able to do anything like that so far .......in fact ....most of my  experiments  have been  a little  less effective than other peoples ...... so maybe I have  a bit if the  reverse  Daniel gene.
gary
