Has somebody used Eric Laithwaite 's device ?
Started by soliris, September 16, 2008, 02:17:16 PM
soliris
You sould be near me to make me understand this figure seven (!)...I just know that another man seems to do experiments like Laithwaite did..I want to talk about Raoul Leon Hatem.
Following his experiences (you could'nt find them on the net, I ve got a DVD that I can put on Youtube, in french) he reprocuced the motions of the solar system gravity, explaining that gravity is the result of the two magnetic poles (attractive/repulsive) of each planet/natural satellite/star, reacting on the two poles of another planet, satellite, star....Gravity is the attractive result of opposite poles: when the same poles can do nothing,  nor pull themselves and nor push, it just remains attractive result.
The states of Europe and America fight against Leon Hatem, cause also of his experiences on free energy    http://www.chillingeffects.org/notice.cgi?sID=945 (Google removals of allegedly unlawful results)
pequaide
See http://groups.yahoo.com/group/free_energy/ then go to files, then to pictures titled 9-27-08 Laithwaite’s figure 7.
3 photographs of Laithwaite’s Figure 7
From position one (photograph one) a small double lever is used to accelerate the pucks on the end of the string; one is accelerated north and one south (relative directions). The center puck is initially at rest and has a mass of 76g; the end pucks have a mass of about 32 grams each. That means the center of mass is closer to the center puck than to the end pucks.
As soon as the end pucks begin moving north and south the center puck begins moving right. When the center puck reaches the center of mass (which is about the center of the table) the end pucks are in the positions of photograph two, directly above and below the center puck. If the center of mass is to remain in position as Laithwaite stated then the velocity of the end pucks will be moving with half their original velocity, and the center puck will be moving with 64/76 *1/2 the original velocity of the end pucks. These velocities conserve linear Newtonian momentum, and the velocities also conserve the position of the center of mass. This is what the experimenter will observe upon doing the experiment.
All this motion is then returned to the end pucks upon moving from photograph 2 to photograph 3. In photograph three the center puck (now on the right side) is again at rest. The energy change from photograph 2 to photograph 3 is 217%. Start the motion in the center (photograph 2) and you can make energy.
soliris
Well Mr Pequaide, thank you for your explanations
I'm ready to believe this experiment like true...
Did Mr Laithwaite have a small theory to give us so accurate details ? Did you realize this experiment again ?
It's sure that we must create our own set to check that...
that's why I begin to start studies in electronics, this year (to make it with small instruments).
