A machine to convert gravity to mechanical energy # 2
Started by brian334, October 04, 2008, 01:08:18 PM
brian334
Dear Hans,
Do you think phase # 1 of my machine will work? If not please explain in detail why not.
ResinRat2
http://www.lhup.edu/~dsimanek/museum/themes/buoyant.htm
Here is a page that deals with your design. It starts with buoyancy and continues to your design halfway down the page under the heading "modifications".
brian334
There is no comparison between the machine you cite and my machine.
The machine you cite has to lift the weight twice in each cycle. At the bottom the weight goes up than it falls down pushing the water up. The weight than has to be lifted again.
brian334
I am still waiting for someone to explain what phase of my machine won't work?
All I get are reasons other machines won't work.
brian334
Dear Mr. Rat2,
Even a fifth grader  can understand why the machine you cite  won’t work. In each cycle the machine has to lift the water from the bottom to the top. You gain nothing.
Can you explain why MY machine won’t work? What phase won’t work?
It should be easy to explain why MY machine won’t work.
