HHO Cell - Stan Meyer Design.
Started by peterpierre, October 11, 2008, 05:01:21 PM
What do you think about my current findings in regards to my interpretation of Stanley Meyers System?
I think you're right on track.
Should work but I have reservations. (please post explanation)
I think you're way off. (please post explanation)
HeairBear
So, just buy an LCR meter and connect it to my cell and voila? It will display the capacitance?
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
peterpierre
That is absolutely correct - and please in gods (or whatever elses) name, consider the short distance of the plates / tubes and do NOT forget to make sure they are isolated so there is no possibility for the water to conduct, else you will have some heavy duty arching / possibly damaged electronics / transformers.
P.S. RE: Meter ... I use the protek d460, it is relatively inexpensive (around $100) and has a lot of programmable functions (including Frequency counter up to 1 MHz, backlit display, capacitance and also a RS232C interface to connect to windows computer, comes with software which displays/stores a graph of your readings for print or later reference) :)
HeairBear
Quote from: peterpierre on March 26, 2010, 10:15:16 AM
Are you replying to my question about the LCR meter? Are you suggesting measuring the cells capacitance when the power is applied to it?
peterpierre
Yes I am replying to that one and no do not measure with power applied, that would be pointless, the isolation recommendation is for when you energize the cell with HV DC ... then the electrodes should be isolated, but also when u measure capacitance. And as I mentioned above I would recommend the protek d460 meter
HeairBear
How do I isolate my electrodes?
