the zero point energy molecule! savior of mankind.
Started by nitinnun, October 17, 2008, 09:30:54 PM
nitinnun
the unsaturated fat from raw flax seed, kills bacteria, fungus, and parasites.
it dissolves saturated fat. just by eating it.
it is also very healthy for everycell in the body.
because every cell mebrane, is made of fat.
especially brain cells.
flax seeds unsaturated fat is good for your skin, hair, connective tissue, organs, mental acuity, and memory.
i soak a few hundred seeds in my mouth, with water.
after a few minutes, the unsaturated fat leaks out.
the result is like a healthy, slippery, chewing tobacco.
for hippies.
amigo
Quote from: Yucca on October 19, 2008, 05:28:02 AM
Thanks for the details Amigo,
I will definitely use U shaped electrodes next time I make. I have never had TEM analysis done, have looked under optical microscope and not seen clumps but that doesn't mean much. But I do know from several experiences that CS works wonders on bacterial infections. Can't speak for antiviral properties yet, I'm always worried about drinking the stuff because I don't want to wipe out my gut bacteria.
Yucca.
I have drank mine without any consequences. If you are afraid about good bacteria, just eat some pro-biotic yogurt later, although most people have an appendix and one of its roles apparently is to produce this bacteria...
I'd like to try an experiment and make CS using structured water, but not sure how to create structured water, though it would have to be distilled one which might beat the purpose of structuring it. Not really sure... :)
amigo
Quote from: nitinnun on October 18, 2008, 10:28:05 PM
what i REALLY want to do, is use silicon in place of carbon.
to make something similar to this:
     O
      I
Cu-Si-Fe
So what you really want is to sandwich the quartz/sand between a layer of copper and iron?
Would require some kind of stabilizer so that SiO2 does not dissolve in water, and probably would need to use something to bring the temperature down to melt sand to begin with.
Perhaps Brown's Gas could be used to melt all three, but then we are introducing oxygen into the compound which would oxidize the metals.
Yucca
Quote from: amigo on October 19, 2008, 12:57:22 PM
I have read that water can contain many different types of structures, and that you can get it to form long chains, not with firm covalent bonds but kind of a loose holding together. When in this long chain polymer like state it is said to be more conducive to cellular processes. Is this the restructuring you are speaking of?
Yucca.
amigo
Quote from: Yucca on October 19, 2008, 05:01:43 PM
Yucca.
I suppose so...I am not exactly sure myself because of all the various ways they claim they structure the water, I am not clear what is the ideal/best way of doing so, or correct one for that matter. Heck, by blessing the water it gets structured as well, the power of intent sufficiently changes the organization of molecules. But I would like to see it, be able to determine that it's structured vs. unstructured and methods of doing so are escaping me at the moment.
