the zero point energy molecule! savior of mankind.
Started by nitinnun, October 17, 2008, 09:30:54 PM
nitinnun
the best way to structure water?
if you place water into a strong DC magntic field, the 2 hydrogen atoms of one water molecule, form a hydrogen bond to the oxygen atom of another water molecule.
forming long strands of polarized water.
this is very similar to how i want to align the copper atoms and iron atoms.
by running electricity through the cell, when the cells contents are still melted.
nitinnun
i just realized something important!
i have 2 sticks of steel, sitting in water.
the resistance is a few k-ohm's.
when i charge the 2 sticks with a 9 volt battery, the resistance becomes so high, that it is unreadable!
when i remove the battery, the resistance becomes SEVERAL m-OHM'S!
and then SLOWLY drops back down to a few k-ohms!
polarized water has increased electrical resistance?Huh??
this is very important too me.
because an electrically resistant substance, allows my ZPE molecule to work.
i think the middle-substance would retain its electrical resistance, if its molecules hardened while in the polarized configuration.
john hutchison's cells cooled off while they were polarized by electricity.
so HIS middle substance would harden into the polarized configuration too!
nitinnun
when i used graphite powder instead of glue, there was a much lower resistance between the 2 terminals.
because graphite powder is a conductor.
the voltage was lower.
but the amperage was higher.
the graphite powder was NOT packed tightly. so i was surprised that the amperage was that high.
if lower electrical resistance means more amperage,
than i could get more amperage out of a ZPE cell, by adding conductors to the middle substance?
to sacrifice voltage, for more amperage?
nitinnun
here is my updated diagram.
if you add many copper/iron atoms, and mix the middle substance VERY well,
than SHEER PROBABILITY will place the copper/iron atoms, where they are useful.
then you charge up both terminals with electricity.
this polarizes the copper/iron atoms.
so that all of their positive poles are facing towards the negative terminal,
and all of their negative poles are facing towards the positive terminal.
this way, when the copper/iron atoms "harden" into "ZPE molecules", the ZPE molecules will send the right charge to the right terminal
this also causes the molecules in the middle substance, to harden into a pattern that increases electrical resistance.
