Ωmega Machine - My gift to the world.
Started by NightBlade, October 19, 2008, 05:55:34 PM
If the energy was indeed coming from the spark the simulation wouldn't show it as it doesn't simulate a spark and the zero point energy or w/e that's being tapped from it. I believe this does not need a spark an technically can be done with solid state components.
hartiberlin
Quote from: broli on October 23, 2008, 06:08:19 AM
You are right, the sparking is not included in the simulation.
So I wonder why at all the simulation is saying that it is overunity.
Normally only the spark effects like electron clustering and oxidation of the
the point contact materials give off free electrons, which come additionally
into the circuit and do the additional energy effects.
Regards, Stefan.
4Tesla
I believe if FETs are used you would need to add toroids because there would no longer be coils from the relays.  You need EMF.. correct?
NightBlade
@AlgoryThm
The self discharge pot wastes energy by connecting the 2 caps from opposite poles, thus neutralizing some power. At the resistance shown in my pictures I've found it will self regulate to the power requirements of the load.
You're right about relays having a limited lifespan but I am currently designing a solid state version.
As FET's go I do believe it will work with a torroid or transformer coil instead of the relay because according to Practical Electronics for inventors, its not the sparking, but the sudden cutoff in current flow that causes these massive voltage spikes.
@Stephan and 4Tesla
You are right, the simulator does not factor spark energy in. And it is the EMF or BEMF that is supplying the power.
I think a FET design using depletion MOSFETS would work to let power through the coil and then shut itself off. Similar to Roger Andrews self switching desktop novelties with a split winding.
Unfortunatly my circuit simulator doesn't have depletion mosfets so I will have to continue experimenting,
AlgoryThm
Nightblade thanks for the explanation! I think I got it...I'll see what I can do with my simulator (Electronics Workbench) and if I can make a virtual replication first. And if this works, I'll then go with a real version. We're waiting for the new design with the MOSFETS man! Upload it here when u have it ready!  :)
