4 Mhz Solid State Radiant Battery Charger
Started by callanan, November 07, 2008, 06:49:55 PM
callanan
Quote from: gotoluc on November 16, 2008, 05:13:52 PM
Ossie my friend :),
very happy to see you ;D... it's been a while ;)
I can see this is a HOT topic and I thank you for the bottom of my heart for the effort to start it and mostly to continue it with your new proposed circuit.
I'm away from home till Nov. 27th so I can't do a replication now but I will once I return.
Thanks for sharing mate
Luc
Hi Luc,
I hope you are well and I share your view that it is important for people to share openly their work with these technologies in these forums for the benifit of all.
I would like to also point out that the circuit I have come up with and presented was said to be derived from the work of Dr. Stiffler and John Bedini for a reason. The reason is that I now believe that true or pure Radiant Energy is made up of very many different frequencies. Just like the white light that the sun generates that is the source of energy for everything. It is also the form of energy that is developed by the circuits and devices of Dr. Stiffler. What I have done with this circuit is to be able to generate this true form of radiant energy and then direct it to charge a battery. Using radiant energy to charge a battery is clearly the work of John Bedini as everyone should well know by now. So this is why I have stated that I have come up with this circuit and device but it has been derived from the work of Dr. Stiffler and John Bedini.
Regards,
Ossie
nievesoliveras
@all
I think that each coil takes the place of an inductor. That is take out one 10uh and put in its place a coil.
Jesus
callanan
Quote from: nievesoliveras on November 16, 2008, 08:53:48 PM
@all
Jesus
Jesus! A coil is an inductor....  ;)
Ossie
nievesoliveras
@callanan
You are right!!! Forgive me I am just learning electronics now. My first contact with electronics was with the bedini motor a year ago.
I am learning fast. Because I need to get a selfrunner done.
Jesus
gotoluc
Quote from: callanan on November 16, 2008, 07:48:18 PM
Hi Luc,
Regards,
Ossie
Thanks Ossie for the reply ;)
We are truly blessed to have the shared work of John Bedini and now Dr Stiffler for our use in new circuits. It help so much when we don't need to reinvent the wheel each time we have an idea ;D. We must learn to appreciate and recognize as you have done Ossie this most essential ground work since without it we have nothing and will gain nothing.
I have much hope we can all work together and further the circuit you are proposing. I have seen some excellent group participation in the water fuel topic which has gone further than I ever expected and is still developing.
I'm confident that you have found a worthy effect to study since you are making the effort to share it.
@everyone... Yes, it is an effort to do this and we should be grateful. So let us post only what will help develop what is being shared here and keep the rest to ourselves since the starting point of a new topic is most important.
Myself, I lost touch with Ossie's great research skills after not being able to understand a new experiment direction.he proposed. I ask you all to help if you can, as success will come when we work as a team. Even though I'm away from home I will see if I can find an electronic component store here and see if I can pickup the needed supplies to replicate Ossie's proposed circuit and share what I find.
Thank you Ossie and all for sharing.
Luc
