Lynnferd Grant HHO Breakthrough
Started by goldenequity, November 14, 2008, 09:33:48 AM
Kator01
Hi Luc,
yes I mean the 40 KHz are switched on and of at a rate of 1000 Hertz. The professionals even use multi-frequency-ultrasonics i.e 2 or 3 different frequencies at the same time.
Pulsed DC ? I do not know, Luc, but my physical knowledge tells me, pure DC would be sufficient because ultrasonic pressure is much stronger than forces created by variation of electric field-strenght in a dielectric.
From all the reseach I have done I only can say that I do not believe in a certain magic disruptive frequency for electrolysis. I rergard this as desinformation distracting the attention. It´s more simple and has to do with sonoluminiscence which occurs even at low frequencies of 10 KHz or even lower than this.
And please notice this : The energy of the UV-Light-pulses created by ultrasonics ( cavitaion/imposion) exceed the ultrasonic power-level by 10 exp 11 !!!
Pay attention to this which makes this story a fairy-tale :
QuoteI have no other verification of this experiment, however I believe it merits telling.
... and I would not dare to physically stay near a 700 Watt-transducer. At this power-level I do not think a glass-cylinder will stand the forces applied by the transducer.
Please read this here :
http://aem.asm.org/cgi/content/full/64/2/465
scroll down to the paragraph "Introduction" where is starts "UW are generated by mechanical ... " and pay attention to the heat-Level and pressure-level generated. We are talling here about temperatur-levels present at the surface of the sun and Mega-Pascal-Preasure-Level !!
Any doubts left ?
If you have a look at professional ultrasonic-cleaner-machines for industry which are about this size of power - they all use heavy steel-cages.
But everyone here is free to believe these stories and act accordingly.
I just share my knowledge I have gained while I do not get lost in non common-sense considerations.
Kator01
Kator01
Hi all,
the attached picture is a screenshot of a book published at sribd :
http://www.scribd.com/doc/7343552/sonoluminescence
Hope you will get the idea.
Kator01
Kator01
Hi all,
excuse me picture is too fuzzy.
New one attached here.
Kator01
goldenequity
Thanks for ALL your input Kator.
Are you planning any experimentation /replications?
Kator01
Hi goldenequity,
you bet, but it will take some time because I am preparing a test-circuit to find out more about Thanes HV-Coil-Behaviour.
I like to repeat my question to you : Did you made any success with this emulsifier-subject ?
I think it´s worth to continue with this.
I was thinking about a test with a Petromax-Petroleum-Lamp. They are cheap and you can easily adapt the nozzles. What do you think ?
This here is a german webside explaining in detail the function ot this lamp and when I read this it was sort of  a trigger for me to think about using water-oil-emnulsion with this type of a device.
http://www.lampenmaxe.de/funktion.php
If experiments fail you just have spent 50 $ and possess a light  you can use if electricity fails
Kator
