Lynnferd Grant HHO Breakthrough
Started by goldenequity, November 14, 2008, 09:33:48 AM
Kator01
Hi goldenequity,
then I put this info at the right spot. I was wondering why I placed  it her instead in the news-section.
@ramset : Yes, unfortunately. I sent him a private message here asking about  his friend who gave him samples
of this stuff, but he simply ignored my question.
Best Regards
Kator
professor
Quote from: starcruiser on November 15, 2008, 09:21:22 PM
I am thinking he resonated the tubes using the pulsing from his modified alternator. He was using DC with an AC component into his steel tubes, which resonate in the ultra sonic range. This would be the only way that would support the claims made by Lynnferd. Is this accurate? I am not sure, the only way to tell is to test this on the bench. Should we use a microwave oven to do this, I say no, unless you are well versed in high voltage. Otherwise try the transducer with a car coil as the HV source perhaps or another less lethal power source.
Do not get me wrong I think this has merit and deserves to be explored.
I wonder what if we used a laser diode which is pulsed at say 40khz to excite the water and then use a ignition coil to energize the water? Could that be the secret to the Stanley Myer HHO plug?
@Starcruiser
I think you are on the right track don't know if the output of a laser Diode is sufficient though even when pulsed.
But I always thought that there has to be mechanical resonance involved. Whether you use tubes or plates I think it
really does not matter, plates simply operate at a lower frequency spectrum which both are audible and must therefore be under 16khz.
I always wanted to use my"Rife" Quartz tube that is filled with argon and try to modulate its RF excited Plasma
with different frequencies. 100 Watts of Rf  should give me more output than a Laser diode.
Just bought two Vehicles that I am restoring, once that is done I may find some more time to devote myself back into this project.
professor
sucahyo
Interesting discussion here :).
Quote from: Kator01 on November 16, 2008, 06:18:15 PMNow the key-question here is : Do we need DC-High voltage or does it work with the 28 khz ? I do not know.
How about both? Like in the first picture.
Second picture is what I think can generate such wave.
I really interested to see the result of this experiment.
Kator01
Hi suahyo,
I would not use  this unsystematic methode. Too many steps at a time. You will not know what is doing what.
Kator01
sucahyo
I see. But I really hope there is plan for experiment with DC sinewave too, even if it is not at high voltage. I hope experiment with electrical frequency do not use AC (which I think disturb electrolysis) or rectified AC (weird / unnatural pulse).
What I really like to now is if pulsed DC can have more effect. At what percentage is the pulse voltage compare to DC voltage for best efficiency. What pulse is better, sinewave, square, etc.
I really like to test it my self, but sadly I don't have the necessary equipment.
What I plan to do with my circuit:
- varying input frequency, finding which frequency is best for hydrogen generation, not water vapor, not oxygen.
- varying output voltage to find out at what voltage it start to be noticable.
- varying pulse vs DC voltage percentage, to find out at what percentage is best.
