Canceling Lenz's Law - Methods
Started by supermuble, November 19, 2008, 03:48:27 PM
supermuble
I would like to start this thread to discuss ways of nullifying the effect of Lenz law.
Most of the free energy motors bypass Lenz law, therefore they can produce more energy than conventional science says is possible. If you remove Lenz law, so much electricity can be made from a generator that it can be made into a closed loop system that is "self powering."
For those of you who don't know what Lenz law is:
Lenz law states that the magnetic fields in a coil of wire will always be formed in opposition to the magnetic field that created it, therefore it always takes more magnetic force to induce more current in a coil of wire. Lenz law basically says that you are ALWAYS GOING TO LOSE ENERGY when you induce current into an inductor (coil).
We do not need to cancel this law (render it invalid), we just need to discuss ways of canceling the negative effect it has on our motors and generators.
Please share examples, patents, pictures, videos and any other information showing how to remove Lenz law !
Nali2001
Lindemann wrote in another forum:
Regarding the works of Jim Murray and his dyna flux generator:
Jim Murray video about his life/works: http://video.google.com/videoplay?docid=6761827664845630969&hl=en
And his generator Patent: http://www.google.com/patents?id=qog8AAAAEBAJ&printsec=abstract&zoom=4&dq=4780632
Thank you for your kind and insightful remarks. With regard to your post about the Jim Murray Generator design, I have known Jim Murray for 20 years and we published this patent in Borderland Magazine back in the 1980's. All of the people I worked with in Santa Barbara, including Mike Knox, Eric Dollard, and Chris Carson, met with Jim Murray a number of times after I moved away in 1992. Jim and Eric subsequently solved the solid-state method for converting reactive power back to real power using Jim's methods applied to Eric's FOUR QUADRANT THEORY of electric waves. All of these things you mention have already been accomplished.
While Jim has built working models of this generator, getting all of the electrical and physical resonances in phase is tricky. The machine does NOT exhibit drag free operation until these conditions are all balanced and synchronized. Still and all, it does PROVE that electric motors and generators are NOT converting mechanical energy into electrical energy. The First Law of Thermodynamics does not apply to properly built motors and generators. For those of us who know the truth, this is not a problem.
As you have correctly stated, there is little purpose showing more precise theory in a forum like this when the model building difficulty only gets worse than what has already been shown. I will tell you plainly, however, that the CONSTANT RELUCTANCE MOTOR is the ticket and special geometries are the method of accomplishment. When the reluctance does not change at all during the power stroke, then the inductance of the circuit remains relatively constant as well. This allows for the design of a true, constant speed, synchronous motor that produces maximum mechanical power on 95% reactive power and about 5% real power. This allows a COP=20 operation as technically feasible.
supermuble
Good Jim Murry video! I watched the whole thing. Steven Greer is the most courageous person there is on Earth, and Jim Murray is helping the right guy, that's for sure. That was an amazing story. Thanks Nali2001!
capthook
Overcoming Lenz’s Law would be a huge benefit and it’s almost hard to believe that after all these years and the technologies of the day and age it hasn’t been conquered.
I have had an interest in this subject, and here is some information I have gathered in the past.  I haven’t  tested any of these ideas, but maybe someone here can make better use of this information than I have thus far.
1.   Lenz Free Coils:  Several proposed coils designs to negate Lenz  http://www3.sympatico.ca/slavek.krepelka/ttf2/fields8.htm
   Fields 8-10 discusses the proposed designs.  I would be interested on comments    from others on these!
2.   Coil/core cogging minimizing coil arrangement: Muller design (1st picture)
   When 1 coil is pulling back, another is pulling forward, equalizing the cogging    forces. (not Lenz cancelling, but helpful with iron cored coils - at the expense of rectifiying each coil individually)
3.   Lenz minimizing coil design: Muller design (2nd picture)
   More of the power is generated further back from the magnets.
4.   No-load (Lenz free) generator U.S. Patent: 6,208,061 (http://www.google.com/advanced_patent_search  and enter patent #)
EDIT: corrected patent # in line 4
