Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
CrazyFox
Cavitation: Specific heat of a plasma
Space pressure in the Eather? In  terms of pressure, that is relative to time? This is the very problem I have difficulty expressing with quatum calculations although you have brought it up in your statement. The distortion of time in fusion plasma in a vortex is the problem I have been addressing. Where is the heat going? By conservation of energy as light in another dimension? I am begining to beleave there is a link created in a vortex or in this case of the linear accelerator, an eddy current. That is why, for instance, if building the Clem Engine, magnetic materials should be avoided in its manufacture. I would suggest using Aluminum-Nickel-Bronze with a Sol Gel coating in this case and runner with a hollow stainless steel (non magnetic) drive shaft. Plasma behave strangely in a magnetic field.....like Ball Lightning. If I were constructing a craft dependant upon plasma fields, I would avoid the use of magnetic material in its structure. Predictability of plasma constants are greatly improved in magnetic field free environment. Ironic about the Cern experiment. Just try to predict particles from a collision that occures in the earth's magnetic field.
madddann
Quote from: Koen1 on December 04, 2008, 12:44:46 PM
Well actually the remark about wire coils was aimed
at the Thrapp "OU cavitation heater" video...
Watching that (several years old) video I see a rod type
thing stuck into the metal sphere, and wires running to it.
The wires are connected to a multimeter, so that would imply
simple electric input.
If you look at the shots where he pulls the thing out to pour
the hot water out of the sphere, and you can get a good look
at about 8 minutes into the video, you can see a gizmo on that
rod, and that gizmo looks a huge lot like a coil.
It certainly does not look like a speaker for producing sound.
Now it could be that he is generating sound waves but then
how does he do it without any oscillating membrane?
And if it is a speaker, then can you tell me what type of weird
rod-mounted coil-lookalike speaker contraption it is?
I think we are talking about exactly the same device here, i just named the thread by the video on youtube 'cause i didn't know how to name it, so i think that "Thrapp OU cavitation heater" is the same thing as "Water heater from WITS", and thanks to you now i finally found where is it discussed, (but there is al ot of mess into  ??? )...
So can you please comfirm that this two threads (in the links below) are about the same thing? THX
http://www.overunity.com/index.php?topic=3403.0
http://www.overunity.com/index.php?topic=6208.0
Dann
sparks
@Crazy Fox
    With a plasma which finds itself with the ions magnetically confined by the electron current about the ion field we have a funny critter.   If this construct is capable of converting heat to electron velocity about itself and a subsequent densification of the matter we have about this contracting matter a cavitation within the spacetime frame itself.  A vacuum within a vacuum.  Weird science around a collapsing heated cold field.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
nueview
hi all
thank you for giving me a hole new approach for this concept to far out for discussion here as some don't seem to be able to get out of there box but to the rest multiple ways may yield multiple results so thanks for the input.
have fun
madddann
Quote from: madddann on December 04, 2008, 03:02:17 PM
Dann
@Koen1
Sorry i messed up one of the links above... but can you just confirm that this is the spheric device we are talking about - in this video here?   THX http://www.youtube.com/watch?v=ZxnEQssJ4FQ&feature=PlayList&p=C9FA62002A6557CA&index=0
Dann
