IST! NEO ZAP! TECK Breakthrough ....
Started by innovation_station, December 13, 2008, 03:23:34 PM
infringer
Yes if you stick a foil baseball card in the microwave it does pretty much the same thing there is arcs on the foil and the fall out from that leaves spots where the foil is blasted off deelectroplating or something lol..
It is crazy but you are correct a lot of things to comprehend beneath the surface of the workings of IST's device.
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
Goat
@ IST
No offense meant by this rebuttal but....Having dealt with Patents before and the fact that you mentioned Magnacoasters version of using magnets,coils and frequencies to get OU would null and void your chances for an improved patent and investors because of prior art.
I still am pulling for you on bettering and improving things if turns out to work for us all but please consider going strictly open source with your ideas before you get hit by the bus of life and loose the chance to make life better for us all  ;D  If history serves here is that every inventor that ever tried to claim OU ended up on the wrong side of town, stay on our turf and you might survive the transition from failure  to success :)
Regards,
Paul
MrMag
I am not sure what some people see in this. The sparks are caused by the plating on the magnets. The voltage/current is running along the outside of the magnet through the plating not through the magnets. Sorry, but I don't think there is nothing special about this breakthrough.
hoptoad
Ist it a bird, Ist it a plane, no, it Ists super spark, able to waste good electricity with a mighty sparking bang.
Faster than a load of Ozzies lookin for a beer at a barbeque, stronger than a pit bull on steroids, able to inspire all to leap to tall conclusions at a single bound.
Yes ists super spark !.   :o  ..........  stay tuned for the next great breakthrough  ::) ..
KneeDeep
SkyWatcher123
Hi folks. I have replicated the NeoZap basic effect. I used a MOT just like innovation used and started with a 2500mah nimh AA cell and it made some pretty good cracks and flashes, then i went to 3 AA's and it was almost deafening the cracks it made and plasma arcs were amazing. I checked as innovation did by shorting the batteries and yellow sparks were barely visible and then i shorted the primary coil and the sparks were a little better but next to no audible noise as far as discharge cracks were heard. Also the 14 guage wire did not stick to the primary mot terminal. Now when attaching seven 1/8" thick by 1" dia. stacked neo magnets the 14 guage wire almost welded to the magnets which of course indicates large amperage along with the high volatge. I then connected an 11W incand. w/ one wire at end of neo's the other at opposite primary terminal and was able to light the bulb to maybe 2 or 3 watt level while this was not possible from quickly striking the primary terminal without magnet attached. This certainly is in line with what Joseph Newman spoke of that current is just gyroscopic magnets so maybe its flowing in a complimentary fashion right through the neo's or its some kind of magnetic compression like Aronn spoke of about the ed gray device as in the water spark plug. Anyway, thanks for sharing this information and yes history does show the only way to do something truly good has to be given freely just as love has to be given freely with no conditions.
peace, love, light
