100% energy saver in the market
Started by gigawattgratis, December 31, 2008, 05:55:18 PM
Cap-Z-ro
I can't remember where I read it but those meters themselves were purported to have energy accelerating properties.
So, who knows what could result from combining the two devices ?
You just never know, is all I'm saying.
Regards...
helmut
Quote from: Cap-Z-ro on January 05, 2009, 07:41:57 PM
Regards...
@Cap  @Hans
Lets do some analysis to see the facts.
Lets assume, one have a small Heater for the bedroom.
Tle label shows. 220V, 55Ohm for the value of the resistor.
Fact is: the Resistor does in a normal environment NOT change his properties.
If the Heater is connectet to the Grid, he takes P=U*I  880Watt
I=U/R  220/55 = 4  Amps    The Power of 880W/h will be charged on your bill.
Now the situation changes without you know.(perhaps)
The Energy supplier encreases the Voltage in his Grid to about 250Volt.
Your Heater in the Bedroom and other Resistors on the Net behave as usual.
But this causes different effects.
Now I=U/R   is   250/55= 4,563 Amps  And the Heater reacts with more Power.
P=U*I = 250 * 4,563 = 1140,75 Watt
What does it mean?
The charge on your Bill encreases by more or less 22%
Without you notest.
"Start of the  joke"
So in this case it might be of use to have a small resistor in spare 16Ohm might be fine,
but this must be able to carry the load of 1140Watt.
"End of joke"
Result:
Actions on both sides of the Meter effects the other side.
helmut
pese
Helmut,
no , is not joke.
You cant not use this as saver at resistance load,
that is true , but manufacturer is (woll not?) not saying this
You can TRUE save on inductive load.
motors, pumps, heatpumps frigidaires and so on.
BECAUSE (you save not - BUT- the counter count to much, because
the phase schiftings that you produce with the inductive loads.
HIS WILL BE COMPENSATED TO TRUE VALUES, so so "shit" not your electrici suppliers.
BU you ship him if you have to much uncompensated Fluarescent light tube
in use.  Becaus each lamp that is driven without "compensating" Cap. , count
to thes at your counter. So the Electricity supplier ask you to compensate such loads
with compensating capacitors ( that is in pricipe only al capacity resistors as an LOAD that your counter turne quicker.
So that is it, i hop that some reader will now understand more from this pricipe ,
that is wellknow, since Tesla/Westinghouse
Gustav Pese
drspark
Pese,
Are you saying, if i go to each motor and inductive load in my home, and correct the power factor, the meter/counter will spin faster, cost more?
and are you also saying that its illegal to do so?
DrSpark
pese
Quote from: drspark on January 06, 2009, 05:39:31 AM
Pese,
DrSpark
I say, if you use this thinggs wothout compensation: you counter counts mor KW that you using.
No electricity seller, give (without asking them) information that iz is better FOR YOU to comensating this .
The are only alsin YOU : If you have to much CAPAVITANCE load, becaouse you have mor Energy that you counter shown it
Gustav Pese
