Quote from: Hoppy on February 28, 2009, 10:51:22 AM
Good points Stefan. I try to avoid experimental boards for the reasons you give but to be honest I don't think my croc lead lash-up is much better!
Hoppy
Hi Hoppy,
yes,croco
cables are also very bad, cause:
1. The wire diameter is normally very thin, so there is a ohmical drop, so they
work as resistors...bad for big currents..
2. the connection between the cables and the croco clamp is very bad,
cause it is normally only cropped into the copper,
so after some time the blank copper oxidizes from the air and
the resistance from croco clamp to cable will  go up.
These croco cables are being manufactured by children cheaply in
China or Asia, so they are not soldered at the ends...
So better get a piece of Wood plate and use some nails, hammer them
into the wood, solder their tips and solder cables directly to the nails
and transistors and components...
This is an easy and cheap way to get a demo device model
rigged up and keep it working without any contact problems.
Surely you have to make sure to use a good soldering iron
to not get bad "cold" soldering points, but this probably can be
measured with an Ohmmeter, if the soldering points are okay.
Also don´t use too thin cables, as there will always be a drop of
voltage across them and a ground cable in a circuit should
be pretty massive to not get any effects of voltage drops,
especially if you work with charging up other batteries, so you
don´t loose too much power in thin diameter sized cables...
Regards, Stefan.
Hoppy
Stefan, yes I'm being lazy and this particular experiment needs good quality hook-ups which is why I mentioned in an earlier post that I really need to use thick cables and solder all connections.
Hoppy
plengo
Today I am letting the fan running even though it is only eating the energy of the battery. I will let run tonight too unchanged and record videos as it happens.
I am right now converting the videos for youtube so that I can publish the ugly, bad and good stuff.
Now some pictures that I took of this running fan as I modified it.
Fausto.
plengo
gadgetmall
Quote from: plengo on February 27, 2009, 09:44:50 PM
so tonight I am having a "eureka" again. Do you know what? I think this baby runs better in the night. I let it run the whole day and all it did is eat energy, but now in the night it creates energy, just like plants!!!
I am very glad I am making many videos to show that, but I don't want to publish in youtube yet, until I really have something that is replicable.  (sorry for my bad English). This thing simply runs better at night.
I will, this time, let it run without any interference from me the whole night and if necessary the whole next day. If it stops in the morning I will let it down. SO in the night I can turn it on again. I will record on video the whole ordeal.
Can someone please interject here and come up with possible theories to explain this and may be even forecast possible experiments and solutions?
@gadgetmall
Are you sure you are running this things during the day?????
Fausto.
O My Side is hurting from Laughing so hard Fausto . ;D I have to say this . ok i see your cardboard mount . are you running the magnet up in the picture or flopped over ? Mine of course is flopped over  . I got one more tidbit  that i can think of . there is a spring and a washer in the front part of the fan . well mine anit there . this makes the fan much deeper and therefor more coverage in the stator area .. I remembered  this because I'm in to the second one and i tossed it too . Mine is running Continuous for a week now . Quacking along . are you using two pots ? and also Mine is running two batts also plus i have a Jt hooked up to the 6 volt with a Vdivider . . I'm trying to keep up with you guys and see if it makes a difference . It Doesn't . It runs with only a little change in speed as the battery takes a hit and recovers . Seems to speed up and slow down .Battery's are very high .. i will measure .. 14.38 on the wet cell 6.65 on the sla 6 volt .. i cant remember exactly but the wetcell was below 13 and the sla was 5 or so . Sorry . i forgot to track it . i got so many other projects Happening and My girl is sick and now i am too . Keep up the good work . I recall that this Might work Better and it might have something to do with the electrons in the air and ionosphere and the moon Phase ..:) Hey just as good a explanation as energy from the vacuum . i do feel it is has a life of its own .. It does Strange things Hardly no one in their life time gets to see and experience . I really Love Mine and when summer hits I'm working on the BIG one . One more thing If you notice in My Video all the connections are Short and on the cap itself .No wire on the transistor cap diode . very compact . only wires are going to the pots and the osc cap and switch . these wont affect the Main circuit  Also My cap and circuit it Directly over (or under) the magnet rotor . It just Misses it By a Wire thickness . I have to sometimes put the wire and transistor down with a pencil if i remove the case . well . Good going guys . Cant wait for the Video Fausto and thank you For sticking with this . You will be very happy when the Circuit is Solid . EDIT**** I made the Comment about the moon before hartiberlin posted the info . so there is something to thats. Very Interesting .
Al
