Real OU-Effect to Share with everyone!!!
Started by Magnethos, February 02, 2009, 08:37:03 PM
Magnethos
Quote from: alan on March 07, 2009, 09:27:05 AM
How do you make radiant energy to do work, or how to create EM from it?
With what does it interact?
What happens when RE is put onto a stator coil? Does it induct a magnetic field?
Anyone can extract all the RE extracting only the electric field that flows BEFORE the current starts to flow. I don't know if we can use directly radiant energy to do work. I remember that Edwin Gray used that form of "Cold Electricity" in a light bulb, but I don't know if we can use it with other devices.
The original Tesla coil wasn't a magnetoelectric device as the "modern" tesla coil showed in any textbook about transformers. The Tesla Coil was an electrostatic generator of continuos high tension and the sparks where absolutely white, not blue. And there was only PURE voltage, without current.
This MAYBE was the true Tesla Coil. Or the True Tesla Coil in a machine. BUT I DON'T KNOW.
http://www.plasma-i.com/assets/site-graphics/tesla/Small-Tesla-coil-designed-f.jpg
NOTE AGAIN: I'm NOT sure.
In the conversion from Electrostatic to Electromagnetic, it seems that Tesla used like a ring and unidirectional impulses (¿?) and in that process automatically current is created.
I know the russians used a similar system to send electricity without loses.
They transformed electromagnetic to electrostatic, then they sent it throught only 1 wire and then they transformed from electrostatic to electromagnetic. That is the way they sent electricity WITHOUT losses.
But I haven't more information about that  ???
I also know that there were a formulas called "Tesla's Electrostatic Induction Laws"
I also know that there is a battery called The "Zamboni Pile". That battery was an electrostatic battery. It produces a lot of kilovots and the legend says that the same battery is runing a clokc in Oxford since 1840!!
rensseak
to ask question is the most easy way to get answers. better let the other do the work!!
PaulLowrance
Quote from: Magnethos on March 07, 2009, 07:07:56 AMMaybe we're a little confusing here because NRG is using 2 kinds of DIFFERENT energies.
It doesn't matter if he's talking about heat energy, mechanical energy, or whatever because when you say there's ***more*** energy you are making a very clear statement. Do you have a new theory that says *more* Bla-Bla energy is less energy than La-La energy?  That wouldn't make sense.
The text in his videos are very clear. One example, "This video shows how the electricity collected in the capacitor has ***MORE*** energy ..."
PL
alan
Quote from: rensseak on March 07, 2009, 10:14:34 AM
true, what are you waiting for, start building to provide me the answers.
but seriously, many here seem to know a big deal, so why not ask questions?
@mag
thanks
isn't this radiant energy (aka negative energy) different in nature than (positive) electrostatic energy, therefore different rules apply?
how does it interact with electrons/charge when released at will, after capturing?
NRGFromTheVacuum
Quote from: Magnethos on March 07, 2009, 07:07:56 AMSo, there is an energy amplification because using very EMag energy, he can produce a 2nd kind of energy that can produce more work. In this case, a special case of OU is proved.
That is correct.....
Quote from: PaulLowrance on March 07, 2009, 10:56:22 AM
PL
My statements in the video where misleading, that was my mistake for which I apologize.
Magnethos explains whats happening very clearly.
Quote from: Magnethos on March 07, 2009, 07:07:56 AMBUT, he hasn't achieved OU because that EMag energy was wasted and hasn't been amplified to more EMag energy.
Quote from: Magnethos on March 07, 2009, 07:07:56 AMHe said that he CAN reach COP > 1 because the system he use is not perfect (he use copper wire and hand switching, so maybe he is drawing a little of power from the battery instead pure voltage). But using the correct wire and the correct switching time, anyone can draw pure voltage, so, the COP > 1 will be possible.
