ENERGY AMPLIFICATION
0 Members and 58 Guests are viewing this topic.
Mr. Teslonian
dear friends and reserchers,
AA.  i am a new enterant to the forum and find a lot of useful information here. the topic of energy magnification really interested me and i read all of mr. tito's hints.
i personally feel, he has some really out of the box thinking and has some excelent ideas, which need to be understood well and developed in a working prototype.
having said that, mr. tito has always hinted no to kill the dipole, using the battery, without using it. isn't it wierd i first thought, but the deeper and deeper reading of some other posts made me very clear that it can be accomplished by a simple arrangement of a high inductance coil, a diode, a capacitor (fast charging and discharging one probably), an efficint switching technique, a 24 v battery and an efficient transformer with a low inductance-low resistance primary, and of course some creative thinking.
i was mulling over and over again and got a very simple yet efficient way in which the above components, if arranged thoughtfully can give out a good testing basis of mr. tito's theory (or device) of the very first stage of his device.
i would like to present my idea here to all of you all and proceed from here only after - either its shot down due to some inherent discrepancies or its accepted for further development.
we might use a reed switch and a magnet near it for tuning the switching time etc. (i actually haven't given it much thought yet)
BB.  if we actually imagine a high self inductance coil as a flywheel that has its own inertia, it acts to oppose any flow of current through it while charginging but once fully charged it goes with the flow of the current, similarly when it is disconnected from the source it tends to maintain its inertia of movement of current flow and tries to oppose the disruption (reduction) in current by inducing a high voltage in order to maintain its inertia of movement, which it acquired during the charging process.
CC. a capacitor on the other hand stores the charge corresponding to the voltage applied acoross its terminal. Lower the voltage - lower the charge. Higher the voltage - higher the charge.
DD. a switching system and a diode is to be used in such a configuration, that it helps us in keeping the capacitor charged with a much higher voltage, as compared to initially put across its terminal by our source battery.
EE. switching system can use a reed switch and a magnet to adjust the switching time to obtain the so called sweet spot when with minimum input we are able to obtain an optimum (maximum ?) output and we also dont waste energy in terms of conversion to heat/light/sound etc.
FF. in this system, we don't need a spark gap at all.
GG. if we put a suitable transformer(s) in the system, which has a primary with a very very low inductance and very very low resitance, we might get something out, which is more than the input in every cycle of switching.
HH. we can have many such systems, running off, just with one source, and the total output of all the systems is higher than the input from the source.
II. some part of energy can be looped back to the source battery, which is exactly equal or slightly more than the input taken from the source battery, thus not kiling the dipole, so to say in mr. tito's own words.
JJ. we for the time being forget about the antenna, avremenko plug and other hints by mr. tito and concentrate on perfecting just one such system, as described.
KK. i may be proved right or wrong, but i do have some conviction that a clever arrangement of simple comonents can really deliver something out of nothing.
---- Mr. Teslonian
P.S.: Lets forget about all we have learnt in the traditional way at least once to check out the cleverness in the arrangement which mr. tito describes. Afterall he has dropped many hints. I appreciate his patience and admire his foresight.
Magluvin
Quote from: weizisky on March 28, 2014, 11:47:36 AM
Hey Mags
the C2 itself is a out put circuit, C2 will release  a volume of electrons  between the two C2's pole plates to produce ozone.
you also can place a L3 to feedsome energy back  to the source, it's up to your need.
Feed 'some' energy back?  L3 wound with L2?  L3 remote receiver?
Ozone?  Can I do something with this ozone below??
Mags
Google
Quote from: From other Planet on March 30, 2014, 01:25:21 PM
Google, I want give u one more hint: the more aggression and hate u show towards others, the less they will want to help u building a working device...  ;)
Hi, thanks for your valuable hint. But you made a very wrong assumption my dear. "Others" can only help others making a free energy device if they themselves have one.
I really dislike disinpho agents, fakers and self illusioned individuals who have no working devices but try to covertly give an otherwise impression to others. I cant help it. Take it or leave it. Youtube is full of such $h!t.
Lets not get misguided by false hopes generated by sickos, who dont even realise what they talk.
And I do belive in self learning through lot of reading and experimenting. If ever I found some wierd unexplained effects, I will put it up here on the forum to let others understand and explain, if they wish to, otherwise I do have access to senior scientists both in academia and engineering field.
So dont worry about me, just carry on with your good work.
Best,
forest
mr Teslonian
it's useless to explain it to disinfo agents here  >:( , just watch how stupid responses move your correct explanation back into history by flooding
totoalas
thats the problem with nerds
accelerated education missed the subject in good conduct which a fifth grader have :'(
