ENERGY AMPLIFICATION
Started by Tito L. Oracion, February 06, 2009, 01:45:08 AM
0 Members and 77 Guests are viewing this topic.
Magluvin
Hey Tek
If you notice, the scope that shows input has a negative scale, of which is reading 13kw, so the sim  doesnt really show fault in producing ou as it isnt there in the circuit.  I have one that is 11w in and 15kw out, havnt found any fault in it and it worked as imagined for the outcome. =]
Mags
TEKTRON
Quote from: Magluvin on December 12, 2010, 12:38:46 AM
Hey Tek
Mags
Hey Tek
Mags
Not to diss.... please show me so can learn...
TEKTRON
Quote from: Magluvin on November 30, 2010, 07:57:49 PM
Teets!    CRON?
Is that where you use iron wire as a core and it is also the secondary coil?
I had the pat from 1907 last night and I lost it, no history, cant find.  I remember it was called a converter  as they did back then and the pat is from Philadelphia pa.
It had shown , like I saw in a tesla pat, a coil of wire(iron) with copper coil around it like a toroid, and it had shown other examples.
Mags
Mags, There is a neat little prog called ZTREE, I use it all the time. it is a file handler, the best thing since sliced bread! Configured and used correctly , it is very powerful. Can FIND ,manipulate and organize ANY FILE. It can even be used outside of the operating system (using Ultimate Boot CD) IF IT IS ON YOUR DRIVE and you know kind of what you are looking for ....DOS feel.. ZTREE.COM(PC&MAC and others if used with U-boot cd.) ;)
Magluvin
Tek
Here is a sim of 12w in to 1kw out using Teslas Igniter pat circuit.  Its source is 2.5v
I will be trying to achieve this using the trisil as the switch.  The key will be to have the inductor on the source to flywheel enough to load the cap to the break over voltage of the trisil.   So the trisil will only stay on for a very short period, so it will depend on the inductor as to if that time is enough to get it going to load the cap to the break over voltage.
Just trying to eliminate the switch.  =]
Mags
Magluvin
Something that needs to be said about the sims.  This one in particular, where it is either the igniter or ozone circuit, they are the same. Being that there is some hype as to the ozone pat being capable of OU, and also the igniter, but maybe less recognized as so, it is very peculiar that I can produce OU in the sim with this circuit. And quite a good amount of it, not just a smiggin or a sprinkle, we are talking about 100 times out vs in.  Margin of error?    ;]
The more I mess with the sim and this setup, I am feeling more in tune with what is going on, and what needs to be adjusted next to better the output.   Im finding it very hard to believe that the sim is so far off.
Im going to write Falstad to see if he can maybe help us with this, as he may be able to tell us if it is an anomaly that cannot equal real life.  Or maybe if he finds it interesting enough, to develop the program a bit further, as in defining air core vs iron or even ferrites. Sidacs Trisils. Motors and bifilars.    Things that we might want that is not in the sim lib.
Dunno, just thinking.
Mags
