SPIRAL MAGNET MOTOR IDEA??
Started by magnetman12003, February 14, 2009, 01:48:55 PM
sushimoto
Quote from: magnetman12003 on February 14, 2009, 07:59:20 PM
Hi You are right about the flywheel. I plan to use a heavy flywheel should I attempt to construct this device
I already pointed out the crank arm will not work as shown in my crude illustration..
If you start replicating it, it would be a good idea,
to start progressing at the same point, where the video has ended.
... Instead of bringing in new elementary principles.
The "Follower Disk" must not make a full revolution
in order tu fulfill its purpose. It does not even need to be a full disk.
The Crankarm was just to swing the magnet out of the "sticky point".
best,
sushi
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
magnetman12003
Hi Guys,
Thanks for all the input. I already rounded up gears and after some more parts right now.  Looking into that one way bearing also.
I am going to give this a try as it seems by looking at the movie it might just work. I guess the magnet spiral design has to be just right also.  By using a heavy flywheel and some powerfull magnets maybe I can keep the spiral moving continuously??
Tom
magnetman12003
Hi Guys,
I purchased a couple of gears and a thought occured to me.  I dont want this to be under powered so I plan to use larger powerful magnets. My problem is space. The next illustration comes to mind which is not in keeping with the spiral concept but if you look hard it works the same way using different polaritys,
I have many powerfull 1.5 inch long .75 inch diameter cylinder magnets.   I have a diameter of 4 inches to work within using those magnets inside the gear teeth..
Illustrated is a plan I think might work??
The LEFT disk has zero or "NO BACK LASH" and is free to turn "ONLY" counterclockwise because a one way clutch bearing is used on its shaft.      Thats the one way follower disk.
The RIGHT disk shaft is secured to a heavy flywheel.  Thats the driver disk and is completely free to turn. In this case clockwise.
Remembering what is stated above can you see this turning continuously?  Observe direction arrows. Teeth are meshed together on both disks.  Both disks pivot in the center.
Open for opinions.
Tom
sushimoto
