Coral Castle 50 year old secret - NOW here REVELED
Started by hammuraby, February 26, 2009, 08:42:03 AM
hammuraby
hi, i am a student-thesist on many many other item that is energy related....
befoure of all the .DEVELOPPEMENT DURABLE (infrastrutture) = gestion of surface water
whit chanalization on altimetric isobare...
and...gravity distribution
as BABYLON 2300ac
(++ water pression conversion inTO air compressed befoure turbinage....
conversion for make SNOW! )- territorial laws,
THEN , recicled braking energy sistem
and SMART GRID sistem...
BUT....many many other;
a little time ago i have found a person very upset about the CORAL CASTLE mistery;
ha remind to me , that i was able to understand "how that is work".....
then i try to explane to you
is a question of de-balance the NM using a gear....
recicling ALL the descharge energy
1) the heavyness (10 000Nm ) of water column  (es diseign: 15cm tube for 60 meters)
from the pool to the bottom of sink can give a force trought a meccanic sistem ,
for upper  4000kg for 25 cm, whit a 4:1 gear...
then the water go down the sink "IT-pozzo" to undergraund water level
2) if we change a gear to 40:11 the loud go down for 27,5 cm ,
and when the weight go down the water flow will be reversed, and the water is pumping from the undergraund to the pool "IT-vasca"
and THIS can  replace ALL the energy-water used  ,
by feed-back to ACCUMULATOR-POOL
I whis to be clear....and easy....
look befoure a fhoto from CC...
then a sistem....
NB:excuse me for my little english...i am italian from bergamo-milan
i wait your comments....if use a easy english,  i can answere more soon
hammuraby
por have a perfect idea, on "what can be done for a commercial usa" safety and perfectinament of this
i try to explain this:
AT FIRST the water pool in surface have to be made easy, whit the bottom impermeabilized in film plastic, or what else, THEN refilled whit gres,broke... fired brik; aVERY idroassorbent material, and very GOOD filter for water;
MUST: because this make a pool safe, the pool will be look like a garden  "suspended" BABYLON
TECH:
SECOND whit a conic gear (or automatic, elettronic drived) you have to find a balance point:
when the rapport between is short, the water go DOWN from the pool to the sink, and the loud go UP
when the rapport is long, the loud go DOWN , and the water will be pumped UP from sink to the pool
THEN the exit that was designed meccanicall, can be oil-pneumatic (best will came)
START TO REACH A RAIN WATER in refilled pool
Koen1
I'm having a little trouble following you, half of what you say is very unclear...
but what I get from your posts is that you suggest Leedskalnin used a water "wheel"
powered generator in the form of a reversible pump with his coils and magnets
attached to the wheel,
and that he used some setup where he had water flow from a tank into a sink,
via the waterwheel/pump, then had the waterflow through the pump reverse
causing a flow from the sink to the tank, and repeating this cycle...?
What I don't follow is how you propose to reverse this water flow
and still make use of the water pressure to power the waterwheel+generator. ???
And I suppose your explanation for his construction of the Coral Castle and moving
the extremely heavy blocks is that he simply produced lots of electricity and used that
to lift and move the blocks?
regards,
Koen
BAHammer
Quote from: Koen1 on February 27, 2009, 07:01:26 AM
regards,
Koen
  Something like that might be possible. If the pipes go into the ground, then the heat transfered to the water could make it rise.
Some similar things are being done with heating buildings by this type of set up.
        Jim
hammuraby
for @ koen
at the first you are right,
but no elettric power is intoduce,
because if you convert a power whit a generator the rent can be  0.9
then a rent of elettric motor is 0.9, (0.9 x 0.9 = 0.81) you luse 0.19 ,
plus ++ 0.19 when the cicle will be reverse motor in generator and generator in motor...
0.8 x 0.8 = 0.64  total waste of energy is 35%
coral castle was only idro-meccanic, no air compressed, no elettricity, not.....
