Buoyancy wheel inside two conditions.
Started by Low-Q, March 04, 2009, 11:29:44 AM
tbird
hi Low-Q,
your design has a lot of points to chat about.  since it is changing rapidly, let's address what is looking at us now.
QuoteGravity and magnetism cancells out the weight of the water pushing on the pistons.
Magnetism cannot affect the weight of water. So that buoyancy force is the only force left.
if we start with cylinders "g" and "c", we find them in a position they can not be.  since they are in the same surroundings, the pistons can not be in different positions in the cylinders.  the only thing that might make a very small offset is the magnets force on cylinder "c".  as we know, the force will be greatly reduced with distance, so at the surface, there won't be much push.
now let's look at cylinders "b" and "f".  at this point in rotation, you are getting closer to the magnet, so the force is getting stronger.  i think it will be so strong that it will prevent "f" from getting vertical.  like all the magnet motors being developed, you now have a "sticky spot" and a buoyancy on the wrong side.
if you add another magnet above, you are giving it another "sticky spot".  this one is because of the attraction.  the magnet/piston won't want to leave.
i think if you work out these "sticky spots", you could have a working magnet motor that so many others have tried to build, without luck.
i'll stop here for now.  if we can work out these problems, we can then address the next.
good luck!
tom
It's better to be thought a fool than to open your mouth and prove it!
erickdt
Quote from: ramset on March 05, 2009, 05:16:52 PM
Hans
And LIFT?[buoyancy]
Chet
Yes, bouyancy... on both sides. "Lift" on one side is "resistance" on the other.
Low-Q
Quote from: tbird on March 06, 2009, 09:56:52 AM
hi Low-Q,
good luck!
tom
Hi,
I have made a new drawing. It's bigger and better. The surroundings are the same for all pistons and cylinders now, as water, or a havy liquid matter, is filled all the way up. There is a vent between the oposite cylinders to let the air go back and forth.
Let me explain the magnets in this drawing:
The bottom stator magnet is with a sertain force preventing the piston to pass through. This is however just temporary, as it is later cancelled out with the same force on the other side. It is called cogging. The important thing is then to reduce this cogging so much so the buoyancy force will be strong enough to make that magnet pass through the repelling forces at the bottom.
That is done by adding an perfectly oposite magnetic force at the top. As the top rotor magnet is approaching the stator magnet on top, it will feel greater and greater attraction, but the repelling forces at the bottom is doing the very oposite, and cancels out the forces at the top - and visa versa. So eventually there is no cogging left to prevent the buoyancy force from moving the wheel.
Initially the magnets was introduced to equalize the force needed to move the mass of water upwards from the lowest to highest point of the wheel. And as the water isn't affected by magnetism, and therfor still is forced downwards by gravity, it will continously try to lift the empty volume at the right side without using the same force to lift the water upwards - which is preventing "conventional" buoyancy wheels from working in the first place.
Br.
Vidar
Low-Q
Quote from: erickdt on March 06, 2009, 12:09:53 PM
Can you please explain what you mean with resistance, and lift on both sides?
Br.
Vidar
erickdt
Quote from: Low-Q on March 06, 2009, 12:33:55 PM
Br.
Vidar
I'm saying what you're calling lift on one side will work against you with an equal ammount of force on the other side (in your original design).
