Buoyancy wheel inside two conditions.
Started by Low-Q, March 04, 2009, 11:29:44 AM
Low-Q
Hi,
I have an idea on how a Buoyancy wheel might work. What we already know is that these wheels does not work, but I have been thinking a little, and tried to imagine what would happen if just the half wheel was under water.
If you take the picture below as an example. (This is a drawing I made a long time ago but I have modified it a bit).
The vacuum tubes is altered in volume, and a rod is fixed on each oposite piston which seal the vacuum. To move this rod back and forth does not require energy other than friction. So it is easy to increase emty space on one side and reduce it on the oposite side. The initial idea was to produce more buoyancy on one side than the oposite side. The idea was further to alow the greater buoyancy on one side to force the wheel to turn around.
The problem is that the weight of water this wheel is trying to push from the bottom of the wheel to the top, requires as much energy as the energy from the buoyancy. So it won't work.
So I had another idea. I filled the water tank half full. So the wheel does not have to move water upwards, beyond the wheels axis, and to the pistons on the top.
Instead, with the half full tank, the water is just moved sideways, or is just tumbeling around in the tank going nowhere. Moving mass sideways does not require energy! The pistons in the bottom of the wheel is moving upwards on both left and right side, so the forces acting on the pistons cancels out. The best had been if the pistons was as hig or higher than water level (not shown), so no force from the water is acting at the pistons at all.
Then you have a wheel where the weight of the mass rotating is practically less on the bottom than the top - all the time. And the lowest weight is on one side of the wheel, and the greater weight is on the other side - all the time.
So left I have only one force to care about, and that is the buoyancy force on the right side which is forcing the wheel to spin counter clockwise.
However, I have a feeling that there is something I have missed. So PLEASE anyone, can you try to find out why this new wheel does not work.
All replies is welcome - but please try to stay objective :)
Br.
Vidar
brian334
It does take energy to move mass sideways.
Low-Q
Quote from: brian334 on March 04, 2009, 11:45:11 AM
Thanks @brian334, I will think on that. My thought was that it only requires energy to acellerate mass in order to move it from A to B, but the kinetic energy is going back when deaccelerating before that mass stops at point B. So no net work is done.
Br.
Vidar
brian334
When things move there is friction, you need to add energy to the system to overcome friction.
Low-Q
Quote from: brian334 on March 04, 2009, 12:41:44 PM
Yes, you're right, but friction is a variable factor that isn't directly related to mass, size, torque, or force etc, so it is controllable as it can be minimized or changed regardless of potential energy found in torque or forces.
I mean, if the friction is all that is to make the water in the tank above moving around, that friction can be changed or controlled. I have taken into consideration that there will be friction, and inertia through water, and inside bearings etc., but what I am looking for is if there is a directional force or torque that works more in one direction than the other - regardless of friction. If it is, the torque will potentially start this wheel even with friction in it.
Do you have any opinion about the design by the way - even if its so there is friction?
Br.
Vidar
