Hydrocars Small Engine Formula
Started by Spewing, March 12, 2009, 04:28:42 AM
ramset
So
Back on topic[Spewing's]
Do you have any ideas on how  the circuit to trigger the injectors will look and PSI ?
Chet
Thanks Grandma
Spewing
Psi is related to flow rate,
You have to build up some pressure to get the system kickstarted, pressure is related to flow rate, they must be good.
ERRRR, ERRRRR Little baby, My Lord,,, Read my math, it may be all you have left of me
The Forumula, Production / 4 was no easy formula for me to come it with, it took me days and many many many numbers to achieve that formula, when he says it was easy he has no freaking ideal what i went threw to gain that formula,,,, There is formulas for other engines,,, but im not sure i'm going to stick around long enough to learn them and share them so ass can tell you how easy it is... a
If its so darn easy why dont you ask mr smarty pants the formula for the other engines ehh???
outlaw, i made an error in yours as well as stevies, stevies was 1k L not sure what yours was, im sick of helping others because they want even try and prove my math wrong, thats the least you could do, try to prove my math wrong. I'm not talking about being 5 numbers off either, realize i calculated that while i posted, im prone to have a 12 digite error margin for the sum i have provided.
Farrah Day
Hydro
Maybe I've got you wrong, because on further consideration, I don't think you could be as stupid as you make out even if you practised for a long, long time. In fact I'm not sure anyone could be genuinely as stupid as you make out.
There can only be one explanation for you then: You are spook, and your mission is to disrupt every forum by recruiting an army of illiterate misfits to degenerate the forums and so prevent intelligent minds from getting together and actually making progress.
Educated people will no doubt see you for what you are - it's just a shame that they will not post and you and your kind are free to roam unchallenged.
I guess this forum is no longer worthy and has sunk far below the level to which most intelligent people are prepared to go in order to take part.
How sad it is when mindless stupidity wins out over intelligence and common sense!
Farrah Day
"It's what you learn after you know it all that counts"
Spewing
Quote from: Spewing on March 12, 2009, 04:28:42 AM
This is a rough single cylinder engine formula. If you dont mind,, call it hydrocars forumula,, i worked very very hard for it.
If you used 7 liters to run your engine, then your formula is 7000/4 = 1750 ccs. Meaning get your *  an injector and that engine will run on 1750 cc's.
If you used 4 liters per min then this is your forumula. 4000/4 = 1000, Get you an injector, and you'll run that engine on 1 liter.
if you used 6 liters per min to run it, then 6000/4 = 1500,, get you an injector!
if you used 5.7 liters to run the single cylinder than 5700/4 = 1425 Get you an injector, run this engine on 1425 cc's!!!!!!
THIS MATH DOES NOT WORK WITH ANY ENGINE OTHER THAN A SINGLE CYLINDER ENGINE< DO NOT APPLY THIS MATH ON ANYTHING OTHER THAN A 1 CYLINDER.
YOUR PRODUCTION / 4 IS HOW MUCH YOUR ENGINE IS RUNNING ON. GOOD DAY
ITS NOT LOOKING GOOD FOR MR MEYER, I better see a phenonomon soon!!!!!!!
The good news, we can generate electricity!!!!!
IT WILL STAND!
Farrah Day
What Maths? Where is the maths that took you days to figure out?
You seem to have picked any random number and divided it by 4! (Wow! 'The Hydrocars divide by 4 Formula' - perhaps you can patent it!).
Don't know what you've got between your ears, but it certainly doesn't consist of brain cells!
Why have you not stayed at Ionizationx, where you are no doubt loved and reverred?
Why don't you amaze the Ionizationx members with your genius - I'm sure they will all applaud you for figuring out how to divide a simple number by 4!  That must have really taxed your calculator!
Blimey Hydro, at this rate you'll be doing percentages and fractions by 2015.
Farrah Day
