Hydrocars Small Engine Formula
Started by Spewing, March 12, 2009, 04:28:42 AM
Spewing
This is a rough single cylinder engine formula. If you dont mind,, call it hydrocars forumula,, i worked very very hard for it.
If you used 7 liters to run your engine, then your formula is 7000/4 = 1750 ccs. Meaning get your *  an injector and that engine will run on 1750 cc's.
If you used 4 liters per min then this is your forumula. 4000/4 = 1000, Get you an injector, and you'll run that engine on 1 liter.
if you used 6 liters per min to run it, then 6000/4 = 1500,, get you an injector!
if you used 5.7 liters to run the single cylinder than 5700/4 = 1425 Get you an injector, run this engine on 1425 cc's!!!!!!
THIS MATH DOES NOT WORK WITH ANY ENGINE OTHER THAN A SINGLE CYLINDER ENGINE< DO NOT APPLY THIS MATH ON ANYTHING OTHER THAN A 1 CYLINDER.
YOUR PRODUCTION / 4 IS HOW MUCH YOUR ENGINE IS RUNNING ON. GOOD DAY
ITS NOT LOOKING GOOD FOR MR MEYER, I better see a phenonomon soon!!!!!!!
The good news, we can generate electricity!!!!!
Farrah Day
Hydrocars... dear, dear me... the mind boggles.
And you wonder why Buzz and I became so intolerant of you.
Here you are doing it again. What for crying out loud are you talking about now?
QuoteIf you used 7 liters to run your engine, then your formula is 7000/4 = 1750 ccs. Meaning get your *  an injector and that engine will run on 1750 cc's.
7 litres?  How many 7 litre single cylinder engines do you know of??
QuoteThis is a rough single cylinder engine formula. If you dont mind,, call it hydrocars forumula,, i worked very very hard for it.
Apart from being your usual meaningless rubbish, it's simple division - you call that a formula? You worked very hard to divide two figures.... what!  The one thing I can say about you hydro, is that you never cease to amaze me! You seriously need your head looking at matey!
If people still can't see just what an attention grabbing, useless muppet you are by now, then I guess they never will.
How Stefan sleeps at night after banning Buzz, while allowing the likes of you to continue spouting this garbage, is quite beyond me!
Farrah Day
"It's what you learn after you know it all that counts"
ramset
Spewing
Yes I see your point COMPLETELY NOW Don't dump[waste] the HHO
Inject it just when you need it [use a lot less HH0 and get the job done]
Can you embellish  on this
Yes with this we can make electricity and power other things [do you have a 3cyl justy?]
Of course ,  We need to show more work done than power used
Thank You
Chet
Thanks Grandma
Spewing
Quote from: Farrah Day on March 12, 2009, 07:36:23 AM
SMALL ENGINES IDLE AT AROUND 800 RPMS, if yours is idling at 1k you got problems.
Your Generator is at 13.3 Revs per One Full Second, Can you comprehend that you retarded little bastard?
Now, you son of a bitch, your valve opens 6.6 times of that second, for 250 milliseconds. And about 750 milliseconds your valve is closed.
Each Rev takes you 1000 ms / 13.3   ("75.1")  milliseconds PER REV.
Since your valve opens 6.6 times in one second, then 6.7 * 75.1 is 495.66 rev's your valve would use when it opens. Since your valve does never stay open A full rev, But only a half Rev,495.66 / 2 = 247.83 SO if your retarded ass just got lost in the math, Then the valve openings consume up an entire total of 247 MS in that one second period.
Now that you know your valve consumes up 247 ms then you know it does it 6.6 times, so again 247/6.6 = 37.4 milliseconds. Your valve stays open 37.4 milliseconds you arogent little infant.
Now i learned your sorry no good non testing ass that the valve stays open at 37.4 ms at 800 RPM's, i hope your sphegettie little brain can compute that.
Now, i can give a shit less how many liters of gas you use to run your engine, you can use 2, 5 6 8 40 liters whatever, i don't care what it is. Whatever you use to run your engine, This math applies.
I never said a 7 liter engine you dumb FUCKING PRICK, Get a life and get a job you no good piece of shit.
IF YOU USED 7 liters to RUN THIS ENGINE, THEN 7000/4 =1750,,, thats what you'll use to run it if you use injections,,, 1750 cc's.. EVEN BETTER
1750 / 60 = 29.1 cc's per second, LETS CHECK THAT
7000 / 60 = 116.6 cc's per second
(1000/116.6 = 8.5763293310463121783876500857633 MS)
in 8.5 Milliseconds you PRODUCE 1 CC, OR  1 MiLLITER of gas. CHECK IT, 8.5763293310463121783876500857633 *  116.6 CC is 1000
NOW YOUR ENGINES VALVE OPENS FOR 37.4 MS ON IDLE EACH TIME, TOTAL OF 246.84 MS ((37.4 * 6.6 = 246ms))
Each OPENING you need 37.4 / 8.5 = 4.4 CC's Per Valve Opening, And there is 6.6 of them, SO 6.6 * 4.4 = 29.04 CC"S PER SECOND you will need to be producing, JUST LIKE I TOLD YOU 7000/4 IS 1750 you need to run this engine. 1750 / 60 IS 29.1 CC"S PER SECOND you Retard.
So you can SEE, 116 / 4 is 29, your idiot ass dont understand Flow rate, How can you EVER understand how to do the math when you have to calculate every 90 Degree's for a 4 cylinder, every 60 Degree's for a 6, 180 for a 2 cyinder, 120 degree's for a 3, 30 deg for a 12.
So how much gas do you need then? Thats right your to fucking stupid to answer the Question~
THE ONLY RETARD AROUND HERE IS YOU, YOUR THE ONLY ONE THAT IS NO HELP TO THIS TECH.
IF YOU NEED 29.1 CC'S OF GAS IN THAT 250 MS TIME PERIODE YOU MUST BE PRODUCING 7.2 CC'S EVERY 250 MS TO GET IT! WHEN YOU ADD ANOTHER CYLINDER AT 90 DEGREE'S THINGS CHANGE, THIS IS WHY THE MATH DOES NOT WORK WITH ANTHING MORE THAN 1 CYLINDER.
YOUR AN AROGENT LITTLE PRICK AND YOU NEED YOUR ASS KICKED, I WANT TO BREAK YOUR ARMS AND SHUV THEM UP YOUR ASS
YOU BETTER START PROVING ME WRONG AND STOP WITH THE RETARDED COMMENTS, BECAUSE I DONT SEE YOU PROVING ANYTHING WRONG, SO YES YOU LITTLE BITCH; IF YOUR USING 10 LITERS TO RUN A 1 CYLINDER, AND THAT MAY BE BECAUSE YOUR PULLING A 5K WATT LOAD, THEN THE SAME MATH APPLIES
10000/4 = 2500 CC'S YOU'LL NEED TO RUN THAT ENGINE IF YOU USE AN INJECTOR. SO YOU CAN TAKE THIS MATH, BASED ON WHAT YOU USE WITHOUT AND INJECTOR, AND DETERMINE WHAT YOU CAN BE USING. SO YES THIS MATH IS VALUABLE, ITS NOT SHITTY THOUGHT LIKE YOU MAKE.
THE DIFF BETWEEN ME AND YOU,,,,,,, I HELP THE TECHNOLOGY, YOU DO NOT, GET A LIFE BIATCH!
Farrah Day
Chet, how old are you 10... 11 years old?
Clearly you're not adult or educated enough to see Hydros nonsense for what it is - you've been brainwashed by their garbage and you're clearly as mad as them now.
I see you've now that you too have completely lost your marbles and gone over to the dark side.
Stefan, this whole forum is becoming a pointless waste of space!  Do something about it before it's too late!
Farrah Day
