Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
h20power
Quote from: kolbacict on April 27, 2021, 01:43:19 PM
I don't understand anyway.
The distance between the electrodes in the cell is millimeters.
The wavelength at 12 kHz is 25 kilometers. 300000000/f.
Hello Again,
This has to do with the physical properties of the tubes themselves as well as the RLC relationship between the inductors and the capacitors. Here is a video going over wind chimes as this is all related to this technology we too work with: [size=78%]https://www.youtube.com/watch?v=AfOb8EIx04k&ab_channel=LeeHite[/size] Now after watching that video you have some idea of the frequencies we will be at and how to go about holding the tubes for the fundamental frequency which is what we are after. The gating frequency is used to tune into this fundamental frequency of the outer tubes.
As for the RLC resonance remember this technology doubles the frequency so if you put in 6 kHz what the cell will see is 12 kHz as the voltage intensifier circuit will double the pulse frequency. In this we are talking about the electrical resonance between the inductors and the capacitors. Here we can tune things to be nearly whatever frequency we want as seen in this RLC calculator: [size=78%]https://www.translatorscafe.com/unit-converter/en-US/calculator/series-rlc-impedance/[/size] as seen you can change the resonance frequency by altering the inductance. Note the typical inductance is in the Henry's and the typical capacitance is in the Pico Farads to get the frequencies in the kHertz range. You can adjust things by altering the variables. But since you already know the size of the resonant cavities and should thus make them accordingly you really only need to keep altering the inductance of the transformer to get the resonance where you want it to be. Just note that these WFC capacitors are in fact variable capacitors which is why there must be a resonance PLL system to lock on to and maintain resonance. As more and more gases are generated those gases displace the dielectric between the plates of the capacitor and it's capacitance goes down. This changes the resonant frequency which is why a PLL is needed in the circuit and it too must be fast enough to keep up with the changes in frequency as the voltages are raised/lowered. Now there are a whole lot of things I am not talking about and won't talk about but I feel this gets the general point across.
I have a whole list of things I use to make these VIC transformers that I came up with through my many dealings with them through experimentation as I went about learning this technology. Plus now that I posted that Meyer turn count data everyone should be able to start making these transformers effectively, but I will not talk much on just what it is I am doing on this part of the technology past what I have already talked about. Just know that these switches have limits and we must design things to not overwhelm them.
All in a good days work,
Edward
related #540 :
Hz,ancient "cycles per second"
rotative engine process change :
https://patentauction.com/patent.php?nb=13017
All engines have LIMITED POWER. < we'll provide 6 TIMES the power with the same amount of fuel because sparks occur AFTER top dead center. Now when a crank rotates to 90 degrees after top dead center (TDC) the explosion pressure drops below 100 psi, but when we have an explosion closer to 90 degrees after TDC the pressure is 600 psi.
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/James_Clerk_Maxwell
" .... When Maxwell became interested in electricity, he wrote to William Thomson, 1st Baron Kelvin, and asked him how best to proceed. Kelvin recommended that Maxwell read the published works of Faraday, Kelvin, Ampère, and then those of the German physicists, in the order given. .... "
                                  home literature,from the temporal Bests ! In original language ?
" ...... in particular in 1864 he predicted the existence of electromagnetic waves , which Heinrich Hertz was the first to generate and prove in 1886. ....."
                           Which was Maxwells "physical model" and which Hertz his "physical model"-view ?!
                                                    by mathematical theory or experimental trials ?!
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Joseph_John_Thomson
By examining the cathode radiation in 1897, Thomson succeeded in providing experimental evidence for the existence of the electron predicted by George Johnstone Stoney as early as 1874 (the electron played a fundamental role in the theories of Hendrik Antoon Lorentz and Joseph Larmor as early as 1892 ).
Thomson was also able to prove that moving electrons could be deflected by a magnetic field,
                        which Heinrich Hertz had previously denied.
                                                  Denied by which "model"-thesis ?
From 19.century theories,divided :
Kinetic gas theory and Electromagnetism
to 21.century both combinated :
gas to electron-/ion gas
to Plasma theory
f.e. https://www.psfc.mit.edu/research/topics/basic-plasma-theory-simulation#:~:text=When%20flowing%20plasmas%20interact%20with%20solid%20objects%2C%20a%20wake%20is%20formed.&text=Understanding%20the%20behavior%20of%20dust,solution%20of%20the%20same%20equations.
https://en.wikipedia.org/wiki/Plasma_(physics)
https://en.wikipedia.org/wiki/William_Crookes
Crookes developed the Crookes tubes,[19] investigating cathode rays. He published numerous papers on spectroscopy and conducted research on a variety of minor subjects. In his investigations of the conduction of electricity in low pressure gases, he discovered that as the pressure was lowered, the negative electrode (cathode) appeared to emit rays (the so-called "cathode rays", now known to be a stream of free electrons, and used in cathode ray display devices). As these examples indicate, he was a pioneer in the construction and use of vacuum tubes for the study of physical phenomena.[20]
He was, as a consequence, one of the first scientists to investigate what is now called a plasma and identified it as the fourth state of matter in 1879.
[21]He also devised one of the first instruments for studying nuclear radioactivity, the spinthariscope.[3][22][23][24]
kolbacict
QuoteJust note that these WFC capacitors are in fact variable capacitors which is why there must be a resonance PLL system to lock on to and maintain resonance. As more and more gases are generated those gases displace the dielectric between the plates of the capacitor and it's capacitance goes down. This changes the resonant frequency which is why a PLL is needed in the circuit and it too must be fast enough to keep up with the changes in frequency as the voltages are raised/lowered.
Okay, I agree with that. :)
PLL is not a problem to do. And you, as I understand it, have a colleague or friend, Gunther, a German.
In a yellow shirt.  :) He dealt with the microprocessor part ...
p.s.And I continue to experiment. I made a 50W generator. 20-50MHz.
water in a syringe has boiled. There is no hydrogen ... :(
But I also thought, if all the water decomposed into hydrogen and oxygen at one moment, it would be an explosion. The volume would increase 800 times .
kolbacict
Take a look ...The temperature is far from 100 degrees. Some kind of gas is released.
Raises the piston. The frequency is about 31.6 MHz. There is an antenna matching device that allows the generator to match any load.  :) This thing is part of a VHF radio station.
p.s.
Today it occurred to me that if you try to dissociate into atoms in your resonant cell, not water, but, for example, alcohol or acetone.The binding energy of hydrogen there is much less than in water with oxygen. it will be easier to break.
h20power
Quote from: kolbacict on April 29, 2021, 10:18:22 AM
p.s.
In order for me to evaluate this I'd need to know at what temperate and pressure the liquid is being held under. There is a reason why I added in 1 ATM as if the pressure is less the water will boil at lower temperatures. We have to look over things like, "Phase diagrams." But note water is something special as both oxygen and hydrogen have practically the same ionization threshold to get the atoms to release their electrons. As for putting something other than water inside of my WFC no way that's going to happen as I a truly focused on the mission at hand to be straying away from it now.
The reason is simple, no other technology can do what this technology can do as it simply has no equal.
