Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
Toolofcortex
Here let me give you an example of bringing a manufacturing process in house.
Instead of paying somebody to assemble my boards, I decided to buy this retrofit kit, to turn a regular oven into a high precision reflow oven.
Total price: 250$ USD.
Its this divide and conquer strategy that will make or break you as a business man.
Lets simulate if I was making this Stephen cell.
Now, I have my pcb software:free
Digikey Parts: ~100$
China PCB shops: 200-300$ I might make a few impedance boards.
I need: A plastic circular tube, and a plastic disk, plastic seperator/holder for the tube: 500$. Glue this. It will all be surrounded by water as suggested so leaks are of no concern.
For the SS tubes: Off the shelf pair, machined third if problems, will look for all off the shelf standards.
I think I would come under 2700$. Ok yeah I'm good at this but still, it was free money, you cant expect alot out of gofundme.
Toolofcortex
https://www.ebay.com/itm/24V-Positive-Negative-Voltage-Regulator-Module-Board-Based-on-7824-7924-x1-/132716246379
Since this is a MOSFET amp, this is all you need.
The cell should be driven by powerful batteries 12-13.8 volts
I think some F4 microcontroller with 3x ADC can do this, but there might till be need for lowpass, I am not sure.
This circuit is for zero programming/turn the knob.
But close to the cutoff, since this is a multiphase type scenario, the imperfections of the filter components play a role in phase shift/amplitude drop.
I would be surprised if you needed more than 10khz, considering that the sine component measure ~500hz in the patent application.
Now if any anomalous effects were detected, perhaps we could figure out other more efficient design topologies.
kolbacict
Yes, not enough time, but unfortunately I have to deal with routine affairs. But I hate these things.
But I will do it anyway. Here is what is already there. Bottom to measure gas volume.
kolbacict
Another tormented thought. Why do I see all cells are two-dimensional? Be it a cylinder in a cylinder or flat plates.If we have a water molecule is a three-dimensional tetrahedron, then can arrange three electrodes in the form of a three-dimensional grid?
And make full use of your three phases.
Toolofcortex
Dont do it.
You will only do it poorly and feel discoueraged.
The cells are as they are because greater men said so and we will copy them.
