The Last TPU Development On The WWW
Started by AhuraMazda, March 19, 2009, 11:33:27 AM
Mannix
Remember the video where the unit that he later cut int pieces is not putting out the correct power.
He takes a speaker magnet and runs it around the edge of the coil
Magnon
Quote from: AhuraMazda on March 29, 2009, 07:04:26 AM
@Otto,
I hope you are having fun with your 5U4s.
You said a lot in this post and I have been thinking about it. Are you not going backwards with the use of tubes if you say they are replicating what the TPU coil  is doing? I have been studying the tube specifications and must say I am not very impressed at what I read Unless, the tube that SM was refering to was something special.
Lakhovski developed a special tube described in US patant 2,351,055. Morrey also had a special tube.
TPU is generating a cylindrical nested microwave pattern around the TPU in a vertical form.
This pattern works as a guide to collect and compress the charged particles from the environment nearby. Microwaves are created by acoustomagnetic resonance effect. Micowaves are also the reason, why the TPU generates heat.
To have microwave emission by acoustomagnetic resonance effect, there must be material present in a applied magnetic field, that contains unpaired electrons. Free electrons are creating this effect also. The electron tubes for exsample contains a lot of free electrons in a vacuum.
--Magnon
AhuraMazda
Quote from: Magnon on March 29, 2009, 02:59:46 PM
@Magnon
If for this effect we need an electron cloud, then would a fluorescent lamp do just as well or do we need a specific type of tube?
MACEDONIA CD
@bruce
yes YOU HAVE  THE   .......  GOOD THEORY <WHERE  TESLA  HAS PICK UP THIS ENERGY  FOR  HIS  ELEKTRIC CAR
I LIKE TO ASK HERE SOME  VERY CLEVER MAN  TO ASK SIMPLE THING
IS POSIBLE  IF YOU HAVE  SOME SMALL RF TRANSMITER  LIKE  <1 WATT>  AND  YOU HAVE  100000000     RECIVERS   HO IS THE  SAME FREKFENCY  OF THAT 1 WATT  RF TRANSMITER
WHAT WHILL BE
DID  RECIVERS  WHILL BE TAKE  MORE  LOADS  TO OVERHEAT  THE RF TRANSMITER   HMMMMMMM
IS POSIBLE TO HAVE MORE  <<I WAIT TO  SEE WHAT  YOU WHILL ANSFER  OF THIS SIMPLE  THING >>
@BRUCE FOR THE  TESLA CAR  YES MAN THERE SOMEWHERE HAS  SOME  TRANSMITER  AND  TESLA  HAS  GOOD RECIVER   WHIT SOME ANTENA > SIMPLE ANTENA
Bruce_TPU
Quote from: MACEDONIA  CD on March 29, 2009, 06:31:16 PM
@bruce
WHAT WHILL BE
The "loop antenna collectors" is simply the circuit potential, set to resonate at the one combined frequency.
It is what the other frequency's are doing, the tube oscillators are placing into the circumference of the collectors that matter.  But the collectors must be tuned properly.
Cheers,
Bruce
